Page 1 of 2 12 LastLast
Results 1 to 30 of 49
Thread: Mystic 138 First Rc Boat assembly.
    Feb 2013
    SP
    23
    Default Mystic 138 First Rc Boat assembly.
    Hello everyone.
    Im starting to built my Mystic and its nobody on my country how know something about this boats, so please I will like to get your help and comments to built that.
    My first question is the drives angle.
    This angle its right or should stay more pararell to the hull bottom line?..
    Sorry of my poor english, I hope you can undestand to me.
    thanks very very much and best regards.
    Jun 2009
    GA
    595
    Those drives are *probably* waaaaay over sized.
    Sep 2013
    759
    Those are the right size for this boat! Looks like a good start so far.
    Feb 2013
    SP
    23
    This drives is the ones sell MHZ for the boat so the size its right but im not sure if should be located a little bit more high for get more pararell hull bottom line. I see other Mystic drives pictures and looks more flat than mine.
    Jun 2009
    GA
    595
    Quote Originally Posted by TheShaddix View Post
    You say good start, but that angle is crazy. I don't know much though. :/ I'm genuinely trying to learn. If something is off, now would be the time to say so.
    Jul 2012
    SP
    975
    As a startpoint your drives must be flat with the botton of the hull. Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    Sep 2013
    759
    These drives require holes drilled into the hull where the support towers sit in order for the locking pin to go in, that's why he can't make them "flat" yet. Now, whether or not the builder knows this I do not know! But that's how MHZ boats are due to their very low height. Ideally, the less angle you have, the better it is as long as you can keep the boat down with weight and balance.
    Btw, if you still can't get the drives to be parallel with the keel, then you could cut squares out of the hull so that the tower bases will sit deeper, this way you'll get them flat.
    Feb 2013
    SP
    23
    Thanks very much every body for the comments and help. Yesterday night before to sleep I refilled the mistake holes with epoxy and CF, this morning assembly again the drives and now the angle looks perfect, now I can setting on +&- angle.
    Now its moment to built the flex shafts and motor mount, please where is the right place to locate those?.
    Thanks very much.
    Greetings
    Feb 2013
    SP
    23
    Could be here good place to locate the motor mounts?.
    Dec 2011
    1,447
    Hey Sebastian, welcome to the forum, glad you went with the 138 I think you'll be happy with it. The drives look MUCH better now. Like the 138 we talked about, the 114 pedestal I modified in similar fashion and the picture shows 2-2.5mm of material was removed allowing the drives to get very very close to neutral. I'm not sure this is even necessary on your boat at this time but its nice to know you have some breathing room.
    As far as the motor mounts go, hard to tell in that picture this is the 138.
    Have you decided on power yet? Lot of options for the 138.
    Feb 2013
    SP
    23
    Hi Mike...your thread its very nice and very fine building. I see the web Modellbaupirat from Germany that you speaking about for, looks very good store, i'll order the lypos support there.
    The motors I'll run its a TP 5660 1000kv with Swordfish 240A and Octura X457...you think will be right this props?.
    Thanks very much.
    Dec 2011
    1,447
    Thank you, I put a lot of time into both of them they're really nice boats to build. The MBP sled system is nice I have a lot of sets, its a little heavy but very strong and everything fits nicely.
    I have run the 1000kv 56-size motor from TP. Definitely powerful with the swordfish 240. I think the 457 prop will be perfect for the hull and power system.
    Big props get funny in the 3/16" size I have snapped a lot of prop shafts going with 465s red. (MBP propshafts) so the octura 457 is the way to go. I think the MHZ shafts are stronger though so you can always try in the future.
    Feb 2013
    SP
    23
    Mike thanks very much for your attention and help on this thread.
    This afternoon while its arriving the motors I assembly the water cooling inlets. Them doesnt get very good fitment to the flat botom hull (first pohoto) so I pass it for the mill. After that fits much better, do you think them are located on right place?
    Dec 2011
    1,447
    Also, with the drives mounted very low the bottom screw might be difficult to tighten since it likely won't sit flush with the transom. A carbon fiber transom doubler will solve this problem. Everything looks awesome so far!
    Feb 2013
    SP
    23
    Thanks very much for your help Mike.
    Today I adjust the motor mounts, using a carbon rods to be sure its straight to the drives and after that glued.
    Jul 2012
    SP
    975
    Looking nice!
    www.grsboats.com.br
    Nov 2011
    SA
    1,837
    Nice looking build, I'm a bit curious about the flex drive to motor setup. You mention you used a piece of CF rod to align the motors. Have you done a test with the actual 1/4' cable mounted to the prop shaft to see if it spins freely? In my experience there is always a nice curve to the cable coming from the drives to motor-collet.
    Feb 2013
    SP
    23
    Thanks for your comment.
    Yes first I mount the carbon rod for check and adjust straight as possible and after flex shaft direct to the drives and runs very smoothly...
    Today I mount the flex shafts. Please any body can check if its right?.
    Thanks very much and regards.
    Feb 2013
    SP
    23
    Nov 2011
    SA
    1,837
    I would not recommend using square flex ends, but rather using a proper collet from MBP or similar. The gap between the tube and collet should also be a bit less than what you are showing. (10mm is good) I have attached a couple of pictures of what a setup could look like (Just an example, not a must) to get an idea of how I built my MHZ138. Please have a look here https://forums.offshoreelectrics.com/...-McLaren-Theme There are a couple of steps showing how I worked it out. I'm not telling you how you must do it, but I notice you have done a couple of things, then asking the forum "did I do that right?" it would be best if you don't drill any holes or glue anything until you are 100% happy with what you are doing. :-) I'm not an expert, by no means! But I also started once, and made mistakes. Working on these boats can be costly, so you don't want to make too many mistakes. Its best to take your time and work it out slowly. What you have already done WILL WORK, and your boat will run. But it looks like you have the skills to make it even better. So you might as well :-)
    Dec 2011
    1,447
    Found this picture of the 114, hope it helps.
    I thought the same thing as Kent. I have no experience with the square flex, but have always used round cables with the MBP collets Kent rec.
    When installing the stuffing tube I like to use CA glue to tack the stuffing tube holder in place, then after scuffing up the area (again) use epoxy. I think the stuffing tube is very important, improper alignment or too much flex exposed can create big problems.
    Motor mounts look good epoxied in, coming out good.
    Sep 2013
    759
    What is the main reason you guys don't want to leave much space between the stuffing tube and the collet? Vibration of the flex? Or water leaks due to being too low in regard to water line? Everyone says it's important or it'll cause issues, but no one really says exactly what those are.
    And why is it better to have such short stuffing tubes? Is there a benefit to that?
    Nov 2011
    SA
    1,837
    If the stuffing tube is very close to the collet and proper aligned, its less likely to snap. If its spaced far apart, the cable can "wobble" under high rpm and snap. leaving a lot of exposed flex cable can also be a good source for getting stuff caught. cable, sponge, paper towel and so on. water will find its way up no matter what :). But vibration causing snap, or getting things caught in a spinning cable would have to be the major reasons.
    Dec 2011
    1,447
    I've never made a stuffing tube short because of concern about cable strength. I think "whip," can become a problem when cables get really long, but most cables are cut to a reasonable length in the mystics, hprs. A lot of people mount the motors in the back since motors of course will be fixed in place, so additional leeway with CG is never a bad thing. I really don't think a flex will break if the stuffing tube is 3 inches vs 4.
    It definitely comes down to preference too, some people mount motors pretty far up if they're confident they know how the hull will perform at speed.
    Feb 2013
    SP
    23
    Sincerely thank you very much everyone for the comments.
    I think that I'll ask for brass tubes again to make them longer.
    Thanks again.
    Oct 2015
    313
    Sick build !
    Sep 2013
    759
    Thanks for explaining! Now I understand. The wobble is definitely a good enough reason to not have a gap. My only hesitation was that removing the motors would take longer if the collets were still on leaving less space for the allen key to work. I'm sure that in this 138 it's not even a problem!
    Feb 2013
    SP
    23
    Nata2Run, please why you dont recommend use a square end flex shaft?. Im making longer flex shafts cover as the photos you show me, thanks for that.
    Thanks very much everybody for your commnets, them are helping me a lot.
    Nov 2011
    SA
    1,837
    Quote Originally Posted by sebasoakley View Post
    I wouldn't recommend purely because of the potential high rpm you can spin. It's not common in a setup like yours to use square shaft ends. Like I nentioned before, what you are doing will work, but there are better ways. A strong true spinning collet, with a good grip on the shaft is much preferred over alternative systems.
    Feb 2013
    SP
    23
    Hi, thanks very much for your replys.
    Please someone knows where should be located the gravity center of this hull?.
    Thanks very much.
