Results 61 to 90 of 118
Thread: Using a Castle ICE Aircraft Controller in FE boats
  1. #61
    Jan 2014
    Md
    323
  2. #62
    May 2007
    1,603
    Quote Originally Posted by dmitry100 View Post
    Would a stick transmitter work better with the castle esc's or would a pistol transmitter like a spektrum dx5r work just as good?
    Can't seem to get the Fixed Endpoints throttle type to calibrate on my 2 castle edge 200's with my futaba 4pls.
    1 controller consistently pulls 5-10k RPM higher than the other while the other motor is at standstill
    You should be able to check the data logs to make sure they are both getting 100% throttle input. I am using aircraft controllers in my boats with a Futaba radio without a problem.
    Sent from my SM-N950U using Tapatalk
    Team Liquid Dash
  3. #63
    Mar 2015
    1,262
    Just how accurate is the Power Out in the data logging?
    On the bench it is saying full throttle is 45% at the moment.
  4. #64
    2,913
    Dmitry
    I though this problem got solved for you in the other thread by Tyler Garrard???
    https://forums.offshoreelectrics.com...-Lehner-motors
    Starting at post #97
  5. #65
    Mar 2015
    1,262
    It was solved, I'm still trying to set the correct trims to acheive full rpm at full throttle by matching the data logging
    Even though its solved for the most part and finally calibrated -- I still notice that each ESC seems to take turns spinning at 10% - 15% throttle blips... It's not a big deal. It's just strange. I assume this is the "castle issue" Tyler mentioned where each castle ESC seem to vary when used for twins.
    It's as if throttle signal slightly varies for both ESC's even tho its connected to the same Y cable.
    I'm sure it'll run fine now on the water once it gets going and won't cause the torque roll flips I experienced when previously.
  6. #66
    2,913
    Torque Roll with a twin when turning at speed.
    If you have your props turning inbound, you will have problems turning at speed.
    When you turn the outside motor loads up in a turn, and the torque of that motor is now trying to rotate the boat even more to the outside, causing a flip.
    This is why I run my props outbound on my twin race Cat, when the outside motor loads up in a turn, the torque of that motor is now trying to hold the boat flat on the water.
    I have found that I can now turn at almost full speed. My "Q" Cat runs at a full speed of 70MPH.
    The top speed of the boat would be a bit faster with inbound props in a straight line, but cannot turn without slowing down (FLIP)
    https://www.facebook.com/groups/1675...1255439039918/
    I do not know if this will work,
    Above is a old video of my cat , when I was still setting it up.
  7. #67
    Mar 2015
    1,262
    It was a pretty slow SAW pass
    and I do understand what you're saying but this was not the case
    Just trying to get the TX to get to full throttle -- the maximum "Throttle In" I'm getting from data logs is 1.965 ms -- One of my other data logs showed Throttle In of over 2.1ms
    What is the max value I should be shooting for?
  8. #68
    Mar 2015
    1,262
    Any of you guys have any idea of just how accurate the Castle data logging is supposed to be?
    I had a separate external data logger hooked up to it complete with current and rpm sensors and all of the data in comparison compared to castle’s was about 2x higher. My data showed max of 40k rpm and 250 amps... castle showed max of 25k rpm, 40% Power Out, and 100 amps. Castle data logging was even set to record at 5x per second.
    Kind of weird. Seems like some pretty useless data...
  9. #69
    If the pole count is not correct for the motor, the rpm will be incorrect. By entering the correct pole count, the rpm shown in my Castle logs matches well with the speeds the boat is running.
  10. #70
    Mar 2015
    1,262
    I've checked before and the pole count was set correctly to 2 pole. But I'll make sure
    Either way, the amps sound a little off -- is it calculated different than what a current sensor between ESC and battery would come up with?
    Even the watts were at 1,400 on castle but 3,300 for my logger.
  11. #71
    Cool
    Have you checked the actual amp hour usage? Time a run and see how much you put back into the packs. Compare that to what the loggers show you used. Then you’ll know.
    My Castles all show virtually identical amps to what I actually used. This also means that watts are correct.
    What is your exact setup?
  12. #72
    May 2007
    1,603
    Has anyone found a good place to buy the 1/8" aluminum extrusion from besides the one that Brian posted? They want $35 to ship a 4' piece...kinda pricey. I have an Edge 200 lite and would like to water cool it asap.
    Team Liquid Dash
  13. #73
    Jan 2013
    Ga
    1,358
  14. #74
    7,631
    Quote Originally Posted by Raydee View Post
    I’ll look to see if I have any spares. I had a bunch made.
    Shawn
  15. #75
    Mar 2015
    1,262
    You don’t necessarily need those particular extrusions. You can make (bend) some L shapes with thin copper or aluminum and use Arctic Silver epoxy (amazon) to glue 1-2 tubes on each side. If you have the original aluminum heat sinks that came with the Phoenix edge 200 — you can simply glue tubes direct on it.
  16. #76
    May 2007
    1,603
    Yeah I see that they changed the design of the ESC and put added a large aluminum plate to them. If I remember correctly when they first came out with the ICE lite series they were only rated at 6s and now they are rated at 8s like the regular version. I wonder if adding that plate added enough cooling to rate them a bit higher? Looks like with the new plate I will just be able to add tubes to that and call it a day. Hopefully its enough to provide the proper cooling?
    Team Liquid Dash
  17. #77
    Jan 2013
    Ga
    1,358
    I been running the 100s like pics I posted without any problems. Here is a 100 and 130 I did. IMG_20180728_181417390.jpgIMG_20180728_181403442_LL.jpg
  18. #78
    May 2007
    1,603
    Quote Originally Posted by jim82 View Post
    Did they both have the aluminum plate on them from the factory?
    Team Liquid Dash
  19. #79
    Jan 2013
    Ga
    1,358
  20. #80
    Jan 2013
    Ga
    1,358
    That is a 200 I haven't finished yet
  21. #81
    May 2007
    1,603
    Ok I see now, looks easy enough.
    Team Liquid Dash
  22. #82
    Jan 2013
    Ga
    1,358
    Not hard at all. I been using this for waterproofing my esc's and receivers so far it has worked great.IMG_20180728_192136041_LL.jpg
  23. #83
    May 2007
    1,603
    Nice that was going to be one of my next questions.
    Team Liquid Dash
  24. #84
    Mar 2015
    1,262
    Raydee, you should be okay. If you want to make it more bulletproof you can just glue aluminum/copper plates to the opposite (exposed) Bus bars and attach them to the stock aluminum heatsink. L shape here.
    I did that + 2 tubes on each side of it and I pulled about 420 amps from them and I’m going to test out some higher pitch SAW props and expect amps to go a good bit higher on my hpr99 twin cat
  25. #85
    May 2007
    1,603
    Nice, 420 amps!
    Team Liquid Dash
  26. #86
    Jan 2013
    Ga
    1,358
    420 spikes not continuous. Im spiking nearly 200 on a 100 with a 2860 5050kv on 2s
  27. #87
    May 2007
    1,603
    Yeah I figured. I originally started looking at the Castle air controllers back when I heard the EDF guys were pulling 400+ amps from them. Knock on wood the ones I am using have been great.
    Team Liquid Dash
  28. #88
    Mar 2015
    1,262
    Default Using a Castle ICE Aircraft Controller in FE boats
    Spikes or not, i think it’s safe to say not many cheap China controllers would handle anything close
    Oh and don’t forget attaching extra caps as close to pcb as possible, if you plan to exceed amp limits. I have about 5000uf of ZL 470uf rubycons on each without pony tail leads (I removed the stock caps). Placed (4) of those in the front
  29. #89
    May 2007
    1,603
    Just curious what diameter shrink wrap you guys are using on the edge 200 controllers after you water cool them?
    Team Liquid Dash
  30. #90
    Jan 2013
    Ga
    1,358
    I will check when I get home
