hell yeah!
Heck, Traxxas should put you on the cover of their magazine!! "First person to hit our claimed goal!"
Looks great!
I think this poor RTR has taken more bashing before released than any....yet better looking than most and a sweet design for motor, etc.
That Garmin GPS is waterproof. No real need to place it in DaBaggie. Ditchin' it will gain you almost nothing in weight reduction though - - HAW !!!
Can't seem to load movie on my iPhone.
^^ me too
We found out the hard way that the gps is waterproof ..... high speed rollover hatch came off even with tape.... recovered the gps in the bag that was full of water lol still gave us a reading of 54 mph thanks to garmin for building a great product we are still in business ....
strange, only a 2.6mph gain running a higher kv motor with a bigger prop
Less efficiency, and less torque^
It's more efficient in it's proper rpm range. 1900kv, on 6s?
GPS reading are almost ALWAY off in the event of a crash. That would be part of the reason for the small difference. The 54 mph reading more than likely was not accurate. Also, like Rum mentioned, the motor may not have had the torque to drive the load that was put on it. For that matter the batteries might not either. Im not sure what your batteries are, but 1900kv on 6s will draw a butt load of amps. There may be more speed there if you can up the mah or c rating.
Yes, the Leopard is more than likely a more powerful motor than the stock vxl, but there is a big difference in load between 1600kv and 1900kv on 6s. I bet that setup pulls over 200A, and thats still only a 120A motor.
I think your missing my point?
most of us understand the load difference between a lower kv to a higher one on the same cells
if he is pulling way more amps than the speedo can run, I'm sure it would pop
even with the same kv Leopard vs the VXL, the Leopard should pull way ahead
kinda like stepping up from the Leopard to a NEU 1521 1.5D on 6s
I am going with the thought of a bad gps reading
We did 3 seperate runs 2 different boats one is totally stock with the 440/3 octura prop got 54.4 mph 2 3s venom 6400 mah batts 20c with 30c max burst...... The other boat ran one run with the leopard 1900kv 120a sea king esc with venom 5400 mah with the octura x442 prop and got 54.6mph the second run same set up with 6400mah batts got 57 mph .... the fourth run is when it flipped and got 54 mph .. we will be running higher c batts and upgrading the esc to squeeze more speed .. this is my first boat and don't know a lot about boat set ups so any advice would be much appreciated ...
What were the water conditions? Smooth, light chop, med chop etc? I've found they run better in water with some med chop. Pulled 58.9 in those conditions.
No. More power from a motor allows you to turn a higher load. The only way the leapard would be faster than the vxl with the same kv and prop is if the vxl was already over its load limit because the effeciance will start decreasing.
On the same thought, if the 1900kv leopard is over its load limit, it will also be less efficient. There are many scenarios where you could take the same can motor in different kv and the LOWER kv could actually run faster.
i was looking at a lower kv motor that could handle more volts so i was thinking higher volts more rpm? two 4s batts or even two 6s but i'm pretty sure i would need a hv esc to handle it ... i know that seaking makes a 80a hv that would handle 160 or 180a bursts but it doesn't make sense to me because if you were to run two 6s batts wouldn't that fry the 80a hv esc?
Why is it when a few guys see someone throw a bunch of volts at a high kv motor, and it goes REALLY fast for a few vids that everyone all of a sudden thinks it is a good idea?
