Holy cow. You are one fo the few guys paying attention! Or smart enough to see that issue. I have been stating for the last 3 years that the best method for an adjustable SV27 stinger to be effective is to cut the stuffing tube off at the transom and modify the bushing arraingement with the stuffing tube.
Here is how I did my SV27's if you bought one from me or listened to what I have been saying. Trim the stuffing tube flush with the transom. Get a new teflon liner so that its one piece. Stock SV27 liners seem to always come on 2 pieces. Change that. Next take an appropriate section of stuffing tubing and solder some "meat" (outer material buildup) to the outside so that when it fits tight into the stinger it doesnt want to rotate. Now you have a stinger that can move any direction you want, be waterproof so no water gets around it and doesnt rotate as the friction from the flex assy wants to impart energy into the bushing assy.
Here is the kicker though. Once you have set the stinger to perform well, chances are very small you will want to move it any direction for the future. If you have "found" the right motor, right speedo and batterie adjustment its no longer necessary. Still. Its a quality upgrade that few even grasp or visualize. Consider yourself among the few who saw the problem right from the start. You have potential grasshopper!
John
Change is the one Constant
