POWER SUPPLY 47 AMP by HP
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    #46
    If you like to push it to the max of its capabalities you need
    24V and up power supply with minimum 40 amps or more to be
    on the safe side.
    1344W only at or above 24v....
    At 12V your charger is 500W max..
    You need stronger power supply, like this:
    The DLS 27V 40A Power Converter/Battery Charger from IOTA converts nominal 108-132 AC voltage to 27.2 DC voltage for both DC load operation and 24V battery charging. As a power supply , the unit's
    Canada
    • kitekook
      • Nov 2011
      • 37
      #47
      what about something like this?
      http://www.hobbyking.com/hobbyking/s...dproduct=22820
        • 7673
        #48
        Can't you just series the HP's?That is what I have.
        • LiPo Power
          • May 2009
          • 3186
          #49
          Thank You, back to my thread topic...
          Many people just do that.
          2 of them in series for 24V 47Amp...
          Canada
          • LiPo Power
            • May 2009
            • 3186
            #50
            HP units
            Newer version with fan installed on the buttom making more room
            for binding posts...
            Canada
            • LiPo Power
              • May 2009
              • 3186
              #51
              Have many, ready to go..!
              Canada
              • LiPo Power
                • May 2009
                • 3186
                #52
                New model is awesome!!!
                Canada
                • CaptPJB
                  • May 2010
                  • 237
                  #53
                  Would like to purcgase a new style charger. Please send PP info
                  Thanks
                  Peter
                  • LiPo Power
                    • May 2009
                    • 3186
                    #54
                    Ok, I will PM you all the info in few minutes...
                    Thank You
                    Robert
                    Thanks
                    Peter
                    Canada
                    • LiPo Power
                      • May 2009
                      • 3186
                      #55
                      I have the new ones tweaked to 13.5 Volts and fixed the temperature sensor location to keep them running cool...
                      Many new ones available....
                      Canada
                      • ray schrauwen
                        • 9471
                        #56
                        Thats sweet!
                        Nortavlag Bulc
                        • LiPo Power
                          • May 2009
                          • 3186
                          #57
                          Weekend Bump for more available!!!
                          Canada
                          • KartRacer
                            • Aug 2012
                            • 355
                            #58
                            Can you give me more info. Guess I'm not seeing how to connect with you.
                            KartRacer ~ Dennis B
                            Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
                            • LiPo Power
                              • May 2009
                              • 3186
                              #59
                              Sure, what info are you requesting please?
                              You can sent me PM with all quastions you have please.
                              Cheers
                              Robert
                              Canada
                              • KartRacer
                                • Aug 2012
                                • 355
                                #60
                                Thanks for the info lipo power, PayPal sent. Deep cycle Battery could not keep up, I will probably add another for 24 volt later on. Getting cold here so runs will be limited.
