Decal Graphics - NO COST
  • dddmx3
    • Mar 2010
    • 233
    #76
    Got any decals that would fit a 37" Genesis?
    After all is said and done, more is said than done.
    • CornelP
      • May 2009
      • 745
      #77
      Ok guys, just came back from a business trip... will start doing some work.
      A reminder: if you want the actual decal, you should either take the graphics I post to a local vinyl shop or contact monojeff (just above). He has the tools and knowledge to do the wraps (looks even better than paint...) and he can also ship a lot cheaper... :P
      • CornelP
        • May 2009
        • 745
        #78
        Boomer, sorry for the delay. See if these look right to you as proportions. The one on the back has to be split to be really visible.
        The Budweiser text is done with the original Bud Select font, not the one in the samples you posted. See the difference in the attached.
        • CornelP
          • May 2009
          • 745
          #79
          @ddmx: not yet, but I'm getting a Fightercat Daytona (the same hull) and I'll do something for that...
          • Alexgar
            • Aug 2009
            • 3534
            #80
            can you do a 4" cartman, my neighbor is a sign maker and has the goods to cut
            • CornelP
              • May 2009
              • 745
              #81
              If you give me a reference photo, yes. Otherwise it's quite complicated to choose a pose...
              Then you have to tell me if you want outline only for a vinyl cut or full color for printing.
              • Alexgar
                • Aug 2009
                • 3534
                #82
                can you pm an email i cant post a hi rez here
                • sailr
                  • Nov 2007
                  • 6927
                  #83
                  How do you make the decals? Are they printed, cut, ??
                  Mini Cat Racing USA
                  www.minicatracingusa.com
                  • monojeff
                    Moderator
                    • Nov 2010
                    • 2562
                    #84
                    Some are printed like a complete wrap wold be a large square or rectangular shape.
                    Others are cut letters.
                    Then you have digital contour cut letters that are printed and then cut around them.
                    Hope this answered your question some.
                    OSE GIFTING ELF
                    HAPPY HOLIDAYS!!
                    • Boomer
                      • 285
                      #85
                      MonoJeff
                      Cornel has graciously created the artwork I needed for the decals for my boat. I am sorry if I seem confused about who does what. It must be an age thing, so please bare with me here.
                      It sounds like you are able to make the actual decals from the proper artwork. If that is correct, can I send the artwork the Cornel ginned up for me? Please let me know and what the tarriff would be for the a set or two of the decals. (Budweiser Select, number 11 and the crown as seen in the pictures in my earlier post.) PM or email me at [email protected]
                      Thank you -
                      Boomer
                      • monojeff
                        Moderator
                        • Nov 2010
                        • 2562
                        #86
                        Originally posted by Boomer
                        MonoJeff
                        Thank you -
                        Boomer
                        Sent you an email.
                        Yes I can make any and all decals & wraps.
                        OSE GIFTING ELF
                        HAPPY HOLIDAYS!!
                        • monojeff
                          Moderator
                          • Nov 2010
                          • 2562
                          #87
                          Thanks Cornel for the shout out.
                          I just tried to open the files you sent to Boomer for whatever reason had some issues and the eps file didn't want to open. One thing to do in the future is to make sure no fonts are embedded and change them to curves/outlines to make things easier to open and nothing gets adjusted when opened.
                          I already had the bud select logos so I just used the jpeg for reference.
                          Not sure how they were saved but something to keep in mind.
                          OSE GIFTING ELF
                          HAPPY HOLIDAYS!!
                          • CornelP
                            • May 2009
                            • 745
                            #88
                            You're welcome.
                            I did forget to convert to curves... I'll just try again, it could be ok this time.
                            Most of the time I use Corel, so I'm not really used to eps format requirements.
                            ps: the file is quite large, even zipped, so I gave up trying...
                            • monojeff
                              Moderator
                              • Nov 2010
                              • 2562
                              #89
                              No worries like I said I just remade it using the jpeg you made for reference.
                              Not sure why it was so large but the file type I would recommend giving to people is a pdf with everything converted to outlines. Usually is a bit smaller then a eps file.
                              OSE GIFTING ELF
                              HAPPY HOLIDAYS!!
                              • dddmx3
                                • Mar 2010
                                • 233
                                #90
                                Boat Designs
                                Alright so I made up some designs, tell me if it's possible to make them.
                                I can send you .eps file of the designs...
                                Please review the attachments.
