I just ordered a new Seaking 120 amp esc, It is replacing an old Seaking V1 or 2 120 amp esc. My question is on the old esc I ran a separate battery pack and did not use the bec, I run 5S should I do the same on the V3 esc or is it safe to use the BEC?
New Seakinmg 120 ESC
I used the bec on the v1 esc on 5s. Not sure why you ran a pack to begin with. Bec is fine to use
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still... -
i dunno man, I've seen those same posts... i always used the built in bec without ANY issuesThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
With the new HW esc's the BEC is a UBEC in the 120 and 180 versions and are pretty good to use but, the 60 amp and 30 amp are Linear BEC that I would not use.
To each his own, sometimes I run a RX pack and sometimes I don't. Spec boats no, modded boats yes.
Nortavlag Bulc
I've always used the BEC even on 6s. That's what they're there for.
Those old posts mainly referred to ESC's with linear regulators . Most ESC's these days use the Switching Mode regulators which can switch higher voltages with much smaller losses.
Ray.
Just as a matter of interest. Where did you see that their smaller ESC's still used the linear mode regulators? I assumed that they used switch mode too. Although I've never used one of those ESC's.
Cheers.
Paul.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
It's right in the specs http://www.offshoreelectrics.com/pro...30a-v3&cat=123
Should be fine though; I've got a 30amp unit to repair a boat that did not need it so, I'll use it for when I ever put my HK podracer together...Specification
Continuous Current: 30A
Peak Current: 180A
Input: 2-3S Lipo
BEC Type: Linear Mode
BEC Output: 6V/1A
Nortavlag Bulc
I think that if you use a external BEC it will provide cooler temps... I think... My SK180V3 runs ok with an external BEC. Up to you. If it was up to me then I would put a cap pack and BEC on it to be extra safe. Also depends what your using it in.Why are you bothering me? I want to see your boat!
32" CF Rivercat--- built by "kfxguy" (SOLD)Comment
