RCBB 200a Speed Controller (2S-7S)
  • Aaron Johnson
    • 49
    Hey Guys,
    I thought I would take the opportunity to plug a product that I have been very happy with. I have had limited experience with boat speed controllers, but have still had the opportunity to run a handful of turnigy, birdie and swordfish branded products. After receiving two swordfish 220a speed controllers which were basically dead on arrival, I was provided to opportunity to use a RCBB 200a unit.
    Unboxing this product, I knew I was on to a good thing. It's physically about 30% larger than the swordwish and T180's. It's a great looking unit with some very neatly setup cap banks and with 8 gauge wires all round. The wires come really long, so you can basically install it into any hull without needing to extend the wires. Simply cut them down to the required lengths.
    Out of the box it appears to be very water tight, which may be a good thing for someone who is not to comfortable with water proofing the unit. But like all boat related electronics I still used a little bit of CorrosionX just to make sure she was good to run.
    Plugging the unit into the provided programing box, I was delighted to see that you have complete control over the setup. I am use to having adjustable punch, timing and battery configuration but this unit also provides you with options such as setting up the throttle curve. You can program timing by 1 degree increments to achieve your desired level.
    Field Test:
    My test boat for this review is a carbon fibre genesis running a single motor configuration. The motor is a TP 1600KV 4060 with a 3/16 drive line spinning a 4814 prop.
    Results:
    Testing the unit against the trusted Turnigy Marine 180a speedie, I was surprised to see how much more power the RCBB provided. I was expecting some better results due to the 20a difference. Running the T180 in my genesis cat, I was able to hit full throttle with speeds maxing out around the 95kmph mark.
    Ripping out the T180 and replacing it with the RCBB 200a, I struggled to get past 3/4 throttle and the speeds were sitting at 101kmph. To reach 100% throttle with this speed controller I am going to have to fiddle with the strut position and wait for a day when the lake is glass.
    The ESC was not even luke warm after a full battery cycle at 6S 50C.
    • 7673
    Looks kinda like one of the Flier ESC's.
    Bigger caps though.
    • Aaron Johnson
      • 49
      Bigger caps though.
      I think you are probably right, maybe a custom spec with the larger cap banks. None the less, that's not a bad thing Flier's seem to have a good reputation.
      What ever they are, they represent good value for money in my eyes. Handy buy for us Aussies down-under.
      • RayR
        @SiestaKey.calm
        • Jun 2007
        • 1518
        Could you show a pic of the program box?
        • ezhitz
          • Aug 2009
          • 428
          This is the program box on the RC Boat Blitz site http://shop.rcboatbitz.com.au/index....oducts_id=1217
          :canada
          • properchopper
            rcgoatbuild@snotmail.com
            • 6968
            RCBB claims that the box is "manufactured by RCBB".
            Here (on the bottom right) is the identical box as supplied for the FCR ESC's. Above it is the Hifei box (likely with the same internals) supplied for a Swordfish ESC I recently got. RCBB claims that their box is "for all RCBB brand ESC's" and they sell Swordfish ESC's.
            Check out this link to see just who OEM's for who. (I'm beginning to think that all Chinese ESC's are made above a noodle shop in Guangzou City)
            Brushed/Brushless motors, speed controls, gear drives - Which (chinese) facctories make various brands of ESC ..? - HobbyKing supplies a useful range of speed controllers, the TURNIGY DLUX ESC range (photos of some models shown below): http://www.hobbyking.com/hobbyking/s.
            • flraptor07
              • Aug 2013
              • 2451
              I've got a Hobbywing surface program box that I used for my SCTs ESCs and I'm using it on all my Hobbywing and Turnigy boat ESCs. I just made a copy of the marine label from their site, it's the exact same box just a different label.
              • Doby
                KANADA RULES!
                • 7280
                All ESC's come from one overseas factory...."ECS's R Us" and at the end of the production lines they get individual shrink wrap and stickers.
                Grand River Marine Modellers
                • properchopper
                  • 6968
                  In some markets they also include a small piece of paper with your fortune on it.
                  • RayR
                    @SiestaKey.calm
                    • Jun 2007
                    • 1518
                    Yep, Flier ESC.
                    • jkr
                      FE Addiction
                      • 568
                      Hehehe a fortune cookie must be supplied also telling you how handsome and strong and fast you are!
                      Sorry but i couldn't resist....
                      • properchopper
                        • 6968
                        Darn - mine said : "Hey Big Boy You Have Much Plobrem"
                        • jkr
                          FE Addiction
                          • 568
                          • Rocstar
                            Joel Mertz
                            • Jun 2012
                            • 1509
                            My ESC came in a take out box and said "Ready in 15 minute"....
                            • jkr
                              FE Addiction
                              • 568
                              BTW Fortune escs are mgm's cause tey have gold layer pcb!
                              But i know one person who makes his escs from pltinum layer pcb......
