TFL Hobbies "Popeye" Hydro: P-Sport Hydro
  • tlandauer
    • 5660
    #961
    Originally posted by Jlov
    Finished the remaining stuff. Mounted in servo and linkage. Got t-nuts mounted and epoxied in. Installed weather stripping for seal on hatch lip. JB welded stuffing tube to strut and sealed hole on bottom of hull. So all done and now it's raining by me today.....
    Heres last pics will post vids after first run.
    [ATTACH=CONFIG]115865[/ATTACH][ATTACH=CONFIG]115866[/ATTACH][ATTACH=CONFIG]115867[/ATTACH][ATTACH=CONFIG]115868[/ATTACH][ATTACH=CONFIG]115869[/ATTACH]
    Jeff,
    Really looks great! Very clean build!
    Mind if I ask what type of tube did you use as stuffing tube?
    • tlandauer
      • 5660
      #962
      Originally posted by ron1950
      anyone tried the new kentec popeye turn fin yet? looks like it might be a decent fin
      Ordered one, just didn't have time to run with it yet! Been too busy setting up the ML PS295 Tunnel, lol....
      • ron1950
        • 3024
        #963
        seeing that its silver id say it may be brass plated silver or aluminum
        • Jlov
          • Nov 2013
          • 825
          #964
          I don't see that new Popeye fin on Kintec. Where on site is it? Tim Ace Hardware sells the 9/32" with 1/4" OD tubing in 3ft lengths. Thx Jeff
          • ron1950
            • 3024
            #965
            look under the popeye tab
            • ron1950
              • 3024
              #966
              looks good jeff...didn't rain on me yesterday in Valrico but darn close lol...nice that u put the motor so far forward now u can balance it right.....I ran mine in 20 mph wind and 4 to 5 inch chop at a race in dallas a few weeks ago...got waxed buy 3 guys from Houston that had set ups for rough windy weather,,,kine was always run in flat water...they couldn't pass me on straight but I could not keep the wet side down in corners....
              • Jlov
                • Nov 2013
                • 825
                #967
                Yes Ron got first run in Monday,got in about 4 laps but then my flex shaft unwound on me and mangled up brass collet insert so waiting on new ones from OSE. Noticed it was a little frayed on tip when I installed it. Tried to solder the tip but obviously unsuccessfully....lol. My motor is almost 1 1/2 inches further forward then it was in my first Popeye but seems to have correct COG. I'm using a custom turn fin that I bought on here from Randy at BBY. It's longer than the UL1 turn fin I had on my other Popeye so anxious to see how it turns with it. Going to order that Kintec one as a back up tho. Jeff
                • JimClark
                  • 5902
                  #968
                  is the kenetic TurfFin on their site? I couldn't find it
                  Billy Graham
                  • ron1950
                    • 3024
                    #969
                    • Jlov
                      • Nov 2013
                      • 825
                      #970
                      I have been running my Popeye on the Y547 since first day. The max GPS reading I've gotten was 54mph on 4S. I'm now using the Castle 1515 2200kv on 5S. Can someone offer a diff prop they've run on their Popeye with success? Thx Jeff
                      • ron1950
                        • 3024
                        #971
                        doby is running a 50mm cnc three blade but his water is a lot cooler then yours id try a 48mm cnc three or smaller I ordered a 48mm 3 but never did try it yet
                        • Doby
                          KANADA RULES!
                          • 7277
                          #972
                          Yeah...but I'm on 4S.....he wants to run 5S....I'd go with something smaller and work my way up.
                          Grand River Marine Modellers
                          • ron1950
                            • 3024
                            #973
                            right id over looked the 5s part
                            • Jlov
                              • Nov 2013
                              • 825
                              #974
                              Not sure now what size you guys are suggesting. What about this prop from OSE?
                              Product ID: octsb-x646/3
                              Octura x646/3 Sharpened & Balanced
                              In Stock: 2
                              Diameter: 1.81" (46mm)
                              Total Pitch: 1.6x1.81=2.896"
                              Shaft Size: 3/16"
                              This propeller is sharpened, balanced and thinned to increase performance over a raw or poorly prepared propeller.
                              Click here for more help in deciding which prop is best.
                              www.offshoreelectrics.com/propeller-chart.php
                              Because of the time & labor required to balance these, they are often out of stock. We suggest clicking the "add watch" button, when the item comes back instock you will receive an email.
                              • tlandauer
                                • 5660
                                #975
                                I'MO the 1.6 pitch with 46mm is pretty aggressive, I may be wrong, but you are on 5s spiining a 2200kv... just saying
                                Sent from my Droid using Tapatalk 2
