product ideas
  • Wetter
    • Aug 2013
    • 241
    product ideas
    Any one using ice packs (blue ice) to cool esc and motor?
    Dow Corning High Vacuum Grease (for rubber boots, "O" rings ect...)
    waxes for swiftness?
    note i have been using (inexpensive LA's totally Awesome CLR @ the dollar store to remove water spots and then spray FW1 cleaning wax) so far so good, with micro fiber towels.
    any of you have somethn' else to add?
    always lookn' for something quick and inexpensive.
    wetter is better
    no fuss just wipe and buff
  • Mattwarner
    • Aug 2011
    • 487
    I'd like to see a duoprop style drive ie one drive but running twin counter rotating props! That would be cool and eliminate the issues of running single motor setups
      • 7990
      I have seen small amounts of "blue ice" used in an inline tube through which cooling water passes, this directly cools the water not the motor.
      Waxed on top, sanded on the bottom - i.e. no wax on the "wet side" of the hull.
      • Wetter
        • Aug 2013
        • 241
        i was just readn' earlier on the sanded bottoms.
        what would happen if boat hulls where dimpled like golf balls?
        would water grip or slip?
        • Heaving Earth
          Banned
          • Jun 2012
          • 1877
          Water and air are completely different elements with different characteristics. A golf ball is designed to move thru air. My guess is, not so well in water
          • Wetter
            • Aug 2013
            • 241
            just thinkn' how to slip thru water faster,
            no coatings like Teflon or Rain-X or somethn' slippy?
