Superhydrophobic and oleophobic coating
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 989
    I plan to do some testing on 1 or 2 of my boats. If the results are unsatisfactory I'll sand it off and find other applications for it around the house.
    • demonioux
      • Dec 2012
      • 7
      No body said oil drops and boat hulls are the same. It was meant just as an example on how objects which have less friction over water interact. I repeat I am not an engenier, I just wanted to express my educated guess "opinion" on the matter which I WILL PUT TO THE TEST the first chance I get. For me its always to test my theories to see how off or not was I from practical aplication. But there are some true facts; for example if you change ANY property of an object the way set object will interact with its eviroment will change... in which way? for me its educated guesses and trial and error. 2) All boat hulls with their strakes and sponsons have been design to perfom with a set
      number of parameters and conditions. Even max speed of hull its determine by its design and over stepping set speed will detriment other aspects of the navigation pure and simple. How much speed a boat can handle maximising control simply depends on the design, and its particular from one hull to another and its setup. Usually speed and handling are inversly proportional.
      Dont get me wrong I will try this stuff and see how it goes
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        Nobody knows until it's tested. Just a bunch of speculation. Sometimes hypothesis doesn't support actual results. Lucky, I'll be interested in seeing what happens as you appear to be the only one buying this stuff
        • demonioux
          • Dec 2012
          • 7
          I totally agree, if someone starts selling this stuff in a smaller package I will buy iuçt too. May be a good idea will be just to coat those parts of the hull where more lift/less frictions are desireable. Just a quoted thougth from someone I know!
          • Cooper
            • Jan 2011
            • 1137
            Hey guys thinking too much it's not going to change the displacement of the hull. The properties are working on a much much smaller level. The wax, sprays, fiberglass gel coat are all hydrophobic in nature. They repel water, water does not mix. Yes testing is needed. The idea that the running characteristics will change- well isn't that what we would be using it for? If they don't change then I guess it's a waste of money. If it runs out of controll which I personally don't see physically happening then maby perhaps a whole new set up is needed with a coated hull. If I can justify $160 for just the boat hull I'm in. I've used similar products on clothes (outdoor) that had to be washed into the fabric but would wear off. Scotch guard is similar, silicone, but this stuff looks like it adheres, penetrates, and functions on a whole other level. Technology is great and hope they come out with a bit smaller version. Seems like this stuff would be wicked wax for our boats!! And would really like to know about the electronics. I wonder how big of a gap the adhesion angle of water would be? I think I read the repel angle was 160 degrees, so I would assume a 1/16 " gap would stop water penetration (under reg atmospheric pressure-not sprayed into).
            • Cooper
              • Jan 2011
              • 1137
              Originally posted by demonioux
              In theory it will be like driving an oil drop over water with minimal adhesion. Techinally it will be suspended on the water unable to break properly water tension (IN THEORY). therefore the hydrodynamic propertys of the hull design will be diminished... At least in theory, many other factors have to be taking into account.
              I kinda disagree here, think of it like a really good coat of wax, when you use a nanotec wax (mcguires I think) the water just runs off the hull. I think the application for this stuff is the adhesion of the actual product and it's longenjevity. Wax wears off pretty quick verses this stuff (if it performs) it ad hears and functions on a much smaller level.
              • Cooper
                • Jan 2011
                • 1137
                Ok I ordered a quart of each, ultra ever dry, something like that from amazon. I'm almost positive it is the exact same stuff just rebranded. I think that is why this stuff has not been publicly available. (the never wet stuff). I was looking alot of this stuff up. I'm still not sure about electronics, but they should be fine to get this coating. I have alot of uses for some stuff at work that's primarily why I purchased. It sounds alot like rejects spray just alot better and alot stronger bond. I dont think it's going to be the super saucer wax (Christmas vacation) but it will help keep things dry. Anyone ski? Snow ski? Well I spent most of my younger life racing and their is alot of money, work, and knowledge that goes into waxes on the bottom of skis. I would imagine the same principal has to apply to fast boat hulls, lessen restriction and friction (drag). I don't want to debate the rough vs smooth hull bottom, as it's pretty obvious smoother hull is less drag. (no one can argue with the laws of physics) but this seems to me to be a gesture in the faster direction. Now how much? That's the question if it's worth it. I have a couple hulls in mind that I can experiment with. I'll have same setup and run a dozen passes, then coat the hull and run a dozen more. It might be a while as I m not in boating season yet. But I will try and give this a validated test effort. So when I get a chance I will post results.
                • demonioux
                  • Dec 2012
                  • 7
                  #23
                  Thats cool keep us posted!
                  • egneg
                    • 4664
                    #24
                    That's the stuff and it does work with electronics. Here is a video with a cell phone. I wouldn't use it on my cell phone as you end up with a cloudy screen but it makes for a great demonstration.
                    IMPBA 20481S D-12
                    • Cooper
                      • Jan 2011
                      • 1137
                      #25
                      Well I was anticipating arrival shortly after my order, instead I just got this the other day.
                      We are following up with all our customers who are awaiting shipment of
                      Ultra Ever Dry products.
                      Due to the extremely high demand, the entire US stock of this product sold
                      out in just a matter of days and every distributor in the country and the
                      manufacturer, Ultra Tech, are out of stock of this product.
                      Ultra Tech is working to finish a new batch of product to fulfill current
                      orders and will have this ready to go around 03/20-03/22. We will have stock
                      heading to our warehouse during this period of time, but are also holding
                      your place in line to ship your order directly from the manufacturer.
                      We will adjust your order accordingly to make sure it ships via whichever
                      location gets the product to you the quickest. We do not want you to lose
                      your place in line for your shipment as there is still quite a backlog of
                      orders behind yours to be filled.
                      If you are unable to wait for shipment of this product, please let us know
                      and we will issue a full refund right away. If you have any concerns or
                      questions, please do not hesitate to reply. Again, we understand that this
                      has been very frustrating, and our goal is to keep working to make sure your
                      order ships as soon as possible.
                      So I guess I'll have to wait a bit. Maybe it's a indicator that this stuff works well or they got one heck of a advertising department and small manufacturing facility. It's almost time for me to start hitting the water so when this stuff gets in ill try and let y'all know.
                      • Bduncan
                        • Jan 2013
                        • 296
                        #26
