Hi Jan,
Firstly thanks for all the bits and pieces, very grateful to have such efficient service, and I am spreading the word amongst fellow rc crew in Oz.
I have got 2 off the upgrade kits from you for the prince/rocket, the kit is the Turnigy 3656-1800kv motor + strut, shafts better coupler etc, I have fitted to both boats and they both have same issues, they are both labouring and refuse to get up on a plane they seem to be lacking in rpm and behaving as if shaft is also slipping? I am just hoping you can spot something I should of done as part of upgrade as both boats are behaving the same. The first time this happened I removed motors and filed flat on shaft for grubscrew to locate upgrade coupler and flex shaft, tried different size 3s 11.1v lipo does perform slightly better with smaller 2200mah bat, but still no cigar.
Another symptom is the rudder control also seems underpowered, I have changed batteries in receiver handpiece, I will try again encase they were dodgy? Any way I will not prattle on as I am just guessing, will appreciate any input you can provide have tried to find answer in forums.
I have a motley crue as well so realise how that size motor should perform,
Thanking You
Colin Jewell
Thanking You
Colin Jewell
I have bought quite a few in the past and really liked them for the $$.................too bad.
