Waterproof servos
  • mtgoat
    • Apr 2008
    • 81
    Waterproof servos
    Traxxas makes a line of waterproof servos. Why have none of the other manufacturers thought of this before? Steve, is there any possibility of carrying these?
  • Eyekandyboats
    • 1921
    traxxas?
    there are a couple water proof servos.
    but mainly not main stream because servos are very eazy to water proof.
    its a box .... just tool dip or cover it in epoxy.
    simple and much better then traxxas servos. especially when you can use your own futaba or JR servo
    EYEKANDYGRAPHICS
    www.rclipos.com
    • ghostofpf1
      • Jun 2008
      • 392
      Originally posted by Eyekandyboats
      traxxas?
      I've used plasti-dip on servos before but if they get a good dunking the water can enter where the output gear exits the case.I've used grease there in the past with varying degrees of success ...
      Ghost
      • JimClark
        • 5907
        Even easier just coat the electronics in corrosion x
        Billy Graham
        • Eyekandyboats
          • 1921
          if you have issues with water going into the grear box....
          make it into a stuffing box. pack that thing with grease..
          EYEKANDYGRAPHICS
          www.rclipos.com
          • Dr. Jet
            • Sep 2007
            • 1707
            I use the Hitec HS-77BB in all my larger boats (large for me is 4S) because they are waterproof, low profile, and have plenty of torque. For the small stuff I use cheap Chinese servos at less than $10 each. If they get damaged by water, it's not a big deal.
            A nation of sheep breeds a government of wolves
            • Steven Vaccaro
              • 8720
              When Mr. Jet pointed me the the 77bb a while back I bought some and they are great. I have been selling them for a while
              • SweetAccord
                Speed Passion
                • Oct 2007
                • 1302
                Yes I just got one of these analog servos.
                They are so far the cheapest ($25.99), lightest 1.23oz (most are 1.3, 1.4, 1.5 oz). Standard size profile to fit standard servo locations (Dimensions: 44x23x25mm / 1.7x0.9x1.0"), very high torque 61.1 oz-in @4.8V, 76.3 oz-in @6.0V), ball bearing, high speed (Speed: .18sec/60° @4.8V .14sec/60° @6.0V, analog servo you can get with Universal Futaba J, Hitec S, JR and Airtronics Z Connector. Great light, powerful, waterproof servo to replace for the standard one that comes with the SuperVee.
                The Hobbico CS-59 Servo Lo Profile Aileron BB U is the next best one but is only about a dollar in price difference, and for that I rather have a Hitec one.
                Great alternative from the Futaba S9550 Servo Digital Low-Profile or the newer Futaba S9551 Low Profile Digital High Speed/Torq Servo that are $80.00!
                • mtgoat
                  • Apr 2008
                  • 81
                  I did end up using one of these Traxxas waterproof servos and can now report that they are, in fact, waterproof.
                  This weekend I accidentally slid the cooling jacket off the end of my motor as I was connecting the batteries.
                  Thank goodness for styrofoam.
                  Although the boat was as full of water as it could be when I brought it back to shore, there wasn't the slightest amount of moisture in the servo when I opened it up.
                  The only disappointing thing about the servo is that it comes with no hardware at all. Not even a servo horn or screw.
