Lifepo4 0850 mah 6.6v receiver pack
  • Steven Vaccaro
    • 8723
    Any one use the Life packs for rx power? I have had a couple of people ask me to carry them.
  • HOTWATER
    • Nov 2008
    • 2323
    I have one of those (Hyperion LiFE 850) for my P-Mono and would like to buy another one....I have not tried it out yet...still finishing my build...
    -Kent
    "Will race for cookies!"
    IMPBA D12
    My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
    • hebner
      • 647
      I had one that worked great until I left the switch on, it drained all the way down and now won't take a charge. I would buy another one if you stock them.
      • Chilli
        • Jan 2008
        • 3070
        If they're Hyperions, I would buy some from you.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • GP73
          • 544
          I've made one from a B&D VPX battery pack, which contains 2 A123 1100mah cells. I think I paid $20 or so, but I can't find more VPX packs around (discontinued)
          For the right price I would definitely buy one or two, either 1100mah or 2300mah cells.
          • keithbradley
            • 3663
            I have (5) 700mah 2s Life packs I use for rx packs. I was concerned about them only being 700mah, but after my first run with one, I charged it and it took 42mah, so it doesnt take much. Im sure if you carried them you would have a hard time keeping them in stock once everyone caught on.
            www.keithbradleyboats.com
            • PaulKTM
              • Dec 2009
              • 20
              I have been using them for over a year now, all my boats have them. These things are great, and pretty good about taking abuse also. Nothing like those 5-15 min. charges either! Hyperion all the way, the Hobbico ones are pretty good also, they make a 200 mAH one that works for the micro boats.
              • sailr
                • Nov 2007
                • 6927
                I use them. I also use a cheap chinese BEC as a voltage regulator as I learned the hard way that some servos don't like the higher voltage of the LiFe packs. Mine are hyperions.
                Mini Cat Racing USA
                www.minicatracingusa.com
                • HOTWATER
                  • Nov 2008
                  • 2323
                  I am also using a Hyperion servo with the LiFe pack...It is an Atlas HV.
                  IMPBA D12
                  • longballlumber
                    • 3132
                    I would be interested in a few as well.
                    Mike
                    • Steven Vaccaro
                      • 8723
                      Thanks for the imput. My only issue with them is that they require an adapter like below.
                      More info on the rx packs can be found here.
                      • ray schrauwen
                        • 9475
                        The balance taps would be enough for Rx power, main leads aren't that useful.
                        I've been using 2S 1000mah lipo packs with Ubec for a while. I don;t like tapping into an esc and the extra wires everywhere.
                        I like the LiFe voltage though. In some boats I would not need the Ubec then.
                        Nortavlag Bulc
                        • longballlumber
                          • 3132
                          http://www.hyperion.hk/dn/fg3radio/default.htm
                          I agree, I don't like the idea of needing an adapter. It's completely uncessary.
                          Mike
                          • Steven Vaccaro
                            • 8723
                            Its another wire and connection that could fail, not to mention the extra money for an adapter.
                            • PDR447
                              • Feb 2011
                              • 92
                              it needs to just charge through the balance tap, then have a standard servo power plug rather than the bullets. that would be ideal.
