OSE 40mm x 74mm motors
  • LaMoparPower
    • Dec 2010
    • 53
    #61
    Very interested to see how these work out..... Starting to build my twin next week...
    Limits only exist when one's scared to test them!
    • m4a1usr
      Fast Electric Addict
      • 2038
      #62
      YOu mean Tacons?
      Yep. You are correct sir!
      John
      Change is the one Constant
      • osprey21
        • May 2010
        • 693
        #63
        I stopped by the PO this morning and picked up my motor - looks good.
        • egneg
          • 4670
          #64
          Originally posted by RCKong
          Or a BAD A$$ P-MONO motor !!!
          Hmmmm ... you have me thinking now!
          IMPBA 20481S D-12
          • G1ST
            • Dec 2010
            • 348
            #65
            Are Leopard and Tacon motors the same?
            • ray schrauwen
              • 9471
              #66
              It seems so. I have a pair of 2860 Tacon's and one 2845 Leopard, look & feel the same.
              Nortavlag Bulc
              • G1ST
                • Dec 2010
                • 348
                #67
                That's what I thought. Thanks
                I've seen ads that look identical (specs, dimensions, & weight) except for the color of the motor. Price can vary wildly also
                • egneg
                  • 4670
                  #68
                  Steven any idea what timing should be used?
                  IMPBA 20481S D-12
                  • RCKong
                    • Sep 2009
                    • 1545
                    #69
                    I ran this motor 2 laps today and one of the motor wires came undone - there was very little solder on it.
                    I'm re- soldering all the motor leads. Oh did I mention it was fast...
                      • 9488
                      #70
                      What are you running yours in?
                      • m4a1usr
                        • 2038
                        #71
                        Do you mean that the wire coming out of the can or one of the bullets? Either cant be good. Thanks for the heads up!
                        John
                        • ray schrauwen
                          • 9471
                          #72
                          John, the factory solder joints are sometimes alot to be desired. I redo them all.
                          Nortavlag Bulc
                          • RCKong
                            • Sep 2009
                            • 1545
                            #73
                            I was testing it in my DF33 on 4s2P. It came apart at the bullet connector. The wire itself had little or no solder on it at all. Probably just a fluke, but I'm gonna make sure it dont happen again.
                            • osprey21
                              • May 2010
                              • 693
                              #74
                              Thanks RCK - I'll now be removing the shrink and checking the joints on mine.
                              • RCKong
                                • Sep 2009
                                • 1545
                                #75
                                BEWARE !!! I don't know how your motor is but mine is
                                - JUNK - I ran it yesterday, and it came apart at the bullet ( no solder ) in a min - never got above 90* in my DF33 with a X645. It took out a brand new T-180 ESC when it unconnected. When I fixed it ( re-soldered ) it cogged terribly, the wires got very hot, it would not run and had to unhook it quickly before it ruined another T-180 ESC
                                I'm sending the motor and controller back to OSE.
                                RCK
