Leopard 56mm water jackets in stock!!
  • forescott
    Hopelessly Addicted to RC
    • 2686
    *****FYI***** Get em while they're hot!!!
  • sailr
    • Nov 2007
    • 6924
    Just ordered one. Now if we could get a motor mount for it! Also can't seem to get a 6 mm x .187 coupler. Out of stock. Long term project waitin for parts! :-)
    Mini Cat Racing USA
    www.minicatracingusa.com
    • forescott
      • 2686
      Thats cuz I just got the last one! Sorry Salir! I'm trying to figure out a way to mod a 540 mount for the 5692 as well. Its a HEAVY motor!
      • sailr
        • Nov 2007
        • 6924
        Not sure there is any way to Mod a 540 mount. Once there is a water jacket on the 5692 it has a HUGE diameter. Steven discontinued the williams mounts doggonit!
        Mini Cat Racing USA
        • ray schrauwen
          • 9438
          Mount
          Nortavlag Bulc
          • forescott
            • 2686
            I have seen a couple like that. A bottom mount would be nice though...
            • sailr
              • Nov 2007
              • 6924
              Mount
              Where did you find that. It's not a williams. Already checked the South River site. Problem is you need rails with that one but that could be easily done.
              The 5692 has an odd mounting hole dimension, 30mm. Most are 25mm or 33mm. A bit of drilling will fix that though.
              Mini Cat Racing USA
              • sailr
                • Nov 2007
                • 6924
                The diameter with the jacket is going to be 2-5/8" +- a bit. Gonna take a tall and wide mount.
                Mini Cat Racing USA
                • forescott
                  • 2686
                  It probably will be best to install a pair of stringers. Especially with a motor mount without any rear support!
                  • m4a1usr
                    Fast Electric Addict
                    • 2032
                    Have Peter whip up something for you guys not wanting a rail mount. He is more then capable to deliver something you will be proud of. He has done many interesting adaptations based on a flat bottom mount for riggers.
                    His 5692 rail mount is a work of art. Truely awesome and strong.
                    John
                    Change is the one Constant
                    • forescott
                      • 2686
                      John
                      I just sent him a pm regarding one of his rail mounts. I was just gonna install a set of rails in my hull. Figured it would be fairly easy to do, and then I would'nt have to re-inforce the hull for a bottom mount.
                      • ray schrauwen
                        • 9438
                        Etamiya.com
                        Nortavlag Bulc
                        • ray schrauwen
                          • 9438
                          29" promise cats. Mine has that mount, needed to drill it out a tad.
                          Nortavlag Bulc
                          • forescott
                            • 2686
                            I am ordering this mount from Peeter Z. Needs 5" rails installed. Nice though!!
                            • ray schrauwen
                              • 9438
                              That ain't cheap.... I should give Peter a shout.
                              Nortavlag Bulc
