I'm looking to carry some of the caps for esc's. Which ones are you guys using?
Caps for esc's
Tags: None
I personally using Schulze 40160 escs, but that cap will be comment for all HV escs, and you should get some 37v caps for LV escs as well.Comment
any difference if ....let say between 5 of 220uf cap and just one 1100uf cap? which way is beter way beside the cost?Comment
Putting more caps in parallel will lower the ESR (Equivalent Series Resistance) of the cap circuit. The drawback is increased realestate that the multiple caps will occupy.
In addition if you are just adding caps, your not boxed in to just using Radials. You can use axials also.Last edited by domwilson; 08-19-2009, 01:16 AM.Government Moto:
"Why fix it? Blame someone else for breaking it."Comment
These are the ones that I bought for my ESC's. These are the same series (ZLH) that are on my castle controllers, with a higher Micro Faren (uF) number. Just another note, I don't run anything that is over 4S.
http://www.newark.com/rubycon/25zlh1...tor/dp/38M3253
For what ever reason, the higher voltage caps (35V and above) are all shipped out of the UK. The shipping charges are much higher...
http://www.newark.com/jsp/search/bro...locale%3Den_USComment
