I.M.P.B.A. Sept. SAWs
  • Doug Smock
    Moderator
    • 5272
    Sponsored by Offshore Electrics
    September 14th,15th, and 16th. at Blue Lake in Valdosta Ga. Exit 13 off I-75, 3 hrs. south of Atlanta. Plenty of lodging at exit 16.
    No pre- registration required. Contest Director, Chris Harris.
    If you have a better mouse trap bring it, or just come out and see what it's all about.
    Steven Vaccaro and OSE have donated a 33"Delta Force mono that we will be having a raffle on.
    If you have never been to a SAWs event you're missing out! So come up, down, over, or around to Blue Lake.
    Great big thank you to Mr. Vaccaro and Offshore Electrics for your part in making this possible, it means alot to us all.
    I'll post some pics and vids as soon as I get home and recover.
    Doug
    [email protected]
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  • Steven Vaccaro
    • 8720
    No problem Doug. I wish you guys smooth water!!
    Steven Vaccaro
    • Doug Smock
      Moderator
      • 5272
      Thank you sir! :D
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Doozie870
        • 828
        Have you guys ever tried to get the motor really cold before a run, like with liquid nitrogen or something? I was reading on the mabuchi site that for every 1 degree the motor resistance changes by .39% I tried to copy the page to post, its pretty neat stuff.
        • SJFE
          • 4735
          You can possibly use freion or a can gum remover..lol. Of course thats a little risky on an abs hull. Can you imagin peggin the throttle and the bottom of the boat just rips out
          • Doozie870
            • 828
            seriously, say you put the motor in the freezer over night and the outside air was 80 the motor would be say 32, 80-32= 48 48 x.39=18.72 thats almost 19% less motor resistance.
            • Mich. Maniac
              Banned
              • 1384
              If you go withthe freezer overnight it would also leave condensation in the motor as it warms. just a thought
              • wickedgmc
                • Jun 2007
                • 719
                a cold motor is a faster motor, much more makes a motor cooler for 540 motors and could work. I know with my 1/10th scale race car I used to use a motor cooler and you could tell. It did end up with condensation on the motor but never caused a problem. This item ran on a 12volt ps, there are others ways to do it as well. Some guys kept the motors in a cooler full of ice to keep the temp down.
                • Steven Vaccaro
                  • 8720
                  My cousin is a electrical engineer for a military firm. They do this with one of their products. They run a tiny radiator system to cool their brushless motors. For them its for both efficiency and more constant results in changing temperatures.
                  Steven Vaccaro
                  • SJFE
                    • 4735
                    There is a company who makes a self contained liquid cooling system for RC. It was about 200 bucks and the pump was around 11 grams. I posted the system on the old forum. I will do some digging and see what I can find.
                    • wickedgmc
                      • Jun 2007
                      • 719
                      is this what you are talking about SJFE
                      • SJFE
                        • 4735
                        Yup. I had considered buying 2 complete systems. I had kiced around mounting the radiators up in the deck in cowels with fans behind them. One system for the esc and another directly to a water jacket. The problems I saw where the amount of coolant volume needed,weight & oh yeah...cost. Maybe a single system on a smaller boat would work.
                        • Mich. Maniac
                          Banned
                          • 1384
                          but unless you have a compressor like an a/c water is still most abundent and coolest. even florida coast line water is in the 60 degrees area I believe. just an opinion, cool but not all that needed.
                          • SJFE
                            • 4735
                            I believe Fluid posted once that the surface tempreture of most lakes and ponds in summer is almost 90 degrees. That really cuts down the amount of heat that water carries away. My aim was to use a synthetic coolant, forced air assist by fans & twin radaitors. IMO that would dissapate more heat than pond or lake water. I googled micro radaitors last night. The only hits I got where for computer systems. to big to heavy. It seems the system I suggested & Wicked found is the only one small enough. I would be looking @ 360 dollars for two systems. Not in the cards anytime soon.
                            • Doug Smock
                              Moderator
                              • 5272
                              I'm thinking if you can't get enough cooling from the lake you run on, your setup is too hot.
                              As far as SAWs go, there are probably more racers that do not use cooling on their motors that those that do.
                              Most Saws boats run for less than 10 sec. and that's both passes.
                              Doug
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
