Terry
Also at the very top page J-2
A ‘pack’ is defined as the cell(s) wired in series or parallel or any wiring combination that is used to provide electrical power to the speed control for the purpose of driving the electrical motor(s).
So when you have all your batteries connected together in your boat in what ever configuration you want except for the last connection to you ESC or ESC's.
This is considered you battery pack for that boat.
For a "Q" boat say you want 6S2P you could use 2 sets of 3 -2S packs in series, then parallel them together to plug into your ESC
This is the point that voltage will be taken to make sure it compiles with the voltage rules.
This setup is your battery pack for that boat.
Larry
Larry
