2nd Titan 29" run with 5S2P zippy LiPo
  • Bigbore
    • Sep 2010
    • 168
    This is my last setup.
    Motor: Feigao 540 10XL 1668Kv
    ESC: Hobbywing Seaking 120A
    Prop: Octura X440
    Battery: Zippy 5000mAh 40C 5S2P tot pack: 5S 10000mAh
    Boat weight: 3,2Kg = 7.0lb
    Vmax= 58Km/h = 36Mph
    COG @ 250mm 9,84in from the transom that is 34% of the total lenght (736mm)
    Is it a wet boat?
  • Doug Smock
    Moderator
    • 5272
    The boat does look a bit wet. I'd move the CG back to 30%, may be able to go as far as 28%.
    She can stand some more prop too. X442, M445 ect. Watch your temps carefully as you go.
    The Titan 29 is a sweet ride.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Bigbore
      • Sep 2010
      • 168
      Doug
      Yes, I noticed the motor got too hot after few minutes run @ full throttle. I have ordered two new battery trays because I must grind the trays that I glued on the bottom of the boat.
      The next day I had a little side wind with some chops and the boat was awesome in the chops.
      This setup I think is very good for the chops conditions, isn't it?
      • Doug Smock
        Moderator
        • 5272
        They are great boats in mild chop and speeds up to 50 mph when setup properly. You do have to watch them carefully when running into the wind.
        Good luck!
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • SweetZ28
          • 1322
          Nice... Like the rooster tail your boat sprays!!
          WWW.PPRSLOTS.COM
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7119
            Great work! i think she looks great, especially for chop. I don't know that I would loosen her up much, since you are running in the sea, where it is not glass. Ahhhhh open water, Italian sea, the beach... Sei molto fortunato! We just broke above 0F (up to -15C from -20C this morning)...
            "Look good doin' it"
            See the fleet
              • 9488
              looks good man!
              I cannot wait to get mine back in after the waters melt
