Video posted. Tomorrow i'll try to put together the how-to. http://www.youtube.com/watch?v=TrebSIwFSvE
Balloon Receiver- Or Chemicals No More
Rust-Oleum Leak Seal is the new great way to dip and seal electronics! Easy and cheap and may be removed if need. Walmart!Comment
Just use the traxxas RX boxes and be done with it. http://www.offshoreelectrics.com/pro...p?prod=dh-3628 I submerged one of these in a 5gal. bucket for a week and it had zero water in it and you don't need to peel all that crap off your Rx if you need to do something with it. Steve is out of stock on them at the moment but there are lots of places to get them.Comment
You really don't need extensions. Covering the pins while coating with DP270 or other is fine. If the connector and pins get wet, it's no different than the extension getting water in it. Just blow them out after a water incident.
i have used the non conductive epoxy before on my reciever board being careful not to get it near the crystal or the 3 pins for the plugs, but with all the low priced 2.4 stuff that is around i was thinking why not just put a few extended harness for 1.2.3 channels and encase the entire reciever in the non conductive epoxy and have a nice little receiver cube and never have to worry again
Nortavlag Bulc
Not everyone has that much room to put a box in their boat. That box would not fit in any MiniCat boat nor in any mini rigger or mini hydro or mono. Plus it just adds unnecessary weight.......Just use the traxxas RX boxes and be done with it. http://www.offshoreelectrics.com/pro...p?prod=dh-3628 I submerged one of these in a 5gal. bucket for a week and it had zero water in it and you don't need to peel all that crap off your Rx if you need to do something with it. Steve is out of stock on them at the moment but there are lots of places to get them.Comment
Correct. But you can even dip past the connections if you wanted to I guess.Comment
You can also apply over already sealed shrink tubed devices like a PisStix instead of dipping too as the shrink tubing is already great water protection. Take a toothpick and apply a little over the existing wires and it will conform easy. Dries evenly also. I'm really loving this stuff, so easy to use and works great and is flexible enough to last stress but not easy enough to scratch off or crack.
CAM00594.jpgCAM00595.jpgComment
I have used hondabond (high grade silicon...much better than regular silicon) to seal the end of heat shrinked items...so far so good. On my receivers and escs i used clear general purpose two part epoxt from walmart. thin coating. then i usually put dielectric grease on the connections.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Hi Oscarel would this servo work set up as dual servo's on Zenoah style outboard linked with arms together push-pullConformal coating works well too http://www.amazon.com/MG-Chemicals-S...7255249&sr=8-2, I get it from Frys. I've also got a GPS that's been encapsulated in casting epoxy and it's worked perfect for the last couple of years, saw the Traxxas guys with one done this way. And for the servos I've started using the new waterproof Hitec ones, http://www.ebay.com/itm/Hitec-HS-564...item58919fb29d
[ATTACH=CONFIG]68742[/ATTACH]Comment
I had a 10th scale hydro that always had water in the tub ..mitch dillard at hsc makes these little tubs for t120 size esc that work greatMY RETIREMENT PLAN?????.....POWERBALL
