Flex Cable Crucible
  • FloatDaBoat
    Bare Bones Fabricator
    • Sep 2009
    • 368
    Flex Cable Crucible
    Here’s how I tin the ends of my flex cables: Purchased an iron pipe cap plug, ground the threads off, clamped the square end in a vise, added chunks of 95% Tin/5% Antimony Plumber’s Solder, heated with a Propane Torch, submerged the rosin coated cable ends into the molten solder. Works like a Champ!!!
    See DaPic . . . .
  • siberianhusky
    • Dec 2009
    • 2187
    Great idea! I haven't thought of a solder pot in years! I've been using my mig welder for a while on cables now, takes about 2 seconds and works great as well.
    • FloatDaBoat
      • Sep 2009
      • 368
      Must be nice! I don’t even have a place to store a welder, even if I could afford one.
      • 49er
        • Jan 2012
        • 7
        This is the neatest idea to come "out of the blue" that I've seen! I've struggled with tinning drive cable ends for years and never thought of this great "old school" solution.
        • Steven Vaccaro
          • 8723
          Its a neat idea.
          have you tried just a soldering iron? I use a weller 80 on upto and including .187 cable with no issues what so ever. The weller 80 is marketed to the stained glass market and holds a ton of heat.
          • Drax21
            • Jul 2011
            • 1021
            Its a neat idea.
            I also use the Weller 80. It's great!
            Everything that has a beginning, has an End
            • martin
              • 2887
              [QUOTE=Steven Vaccaro;387219]Its a neat idea.
              have you tried just a soldering iron? I use a weller 80 on upto and including .187 cable with no issues what so ever. The weller 80 is marketed to the stained glass market and holds a ton of heat.[/QUOTE
              Do you find the Weller 80 good for bullet plugs as well, i was looking at getting one myself.
              • Drax21
                • Jul 2011
                • 1021
                [QUOTE=martin;387526]
                Its a neat idea.
                I use the weller 80 watt with 5.5 and 6mm bullets all the time including silver solder. It does the job every time.
                • SirBudman32
                  • Aug 2011
                  • 625
                  I got one from harbor freight 180 watt and does them with no problem. And for only 12 dollars, cant go wrong
                  Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                  • Steven Vaccaro
                    • 8723
                    Its a neat idea.
                    Yes they work quite well on the plugs also. the iron is large so it takes some getting used to.
                    • DINO7
                      • Jan 2009
                      • 162
                      nice mini soldering pot
                      H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
                      MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
                      BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
                      • worriedsick4u
                        • Dec 2011
                        • 693
                        So is silver solder best for tinning flex cables? Flux needed?
                        • rcboatmanwithkids2880
                          • Aug 2008
                          • 340
                          Hi Guy's ,
                          That Soldering Unit Pot has an Austtralian Power Plug on it , I thought we were the only ones using it. ???
                          Brad
                          Oz
                          Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
                          • sailr
                            • Nov 2007
                            • 6927
                            Do the Aussies use 250V or 110V power mains?
                            Mini Cat Racing USA
                            www.minicatracingusa.com
                              • Aug 2008
                              • 340
                              Hi Salir ,
                              We use 240V .....
                              Brad
                              Oz
