OPC Lower Units and FE Conversion Kit
  • Darin Jordan
    • 8335
    Hey Gang... for those of you interested in racing OPC Tunnels, I thought I'd point you to a source for another option for lower units and an FE conversion kit for them.
    I've seen these in action and they work VERY well...
    I have NO affiliation with these guys, but just wanted people aware so maybe we could get some more P-OPC tunnels out there running and racing!
    Darin E. Jordan - Renton, WA
  • sailr
    • Nov 2007
    • 6927
    Their stuff is beautiful be get ready to write the check!
    Mini Cat Racing USA
    www.minicatracingusa.com
    • teach
      • Jun 2008
      • 509
      Anyone try these out yet?
      • raptor347
        • Jul 2007
        • 1089
        I like mine alot. I have both the 3.5 and 7.5 sizes.
        Brian "Snowman" Buaas
        Team Castle Creations
        NAMBA FE Chairman
        • teach
          • Jun 2008
          • 509
          Are you running the angle drive version or the bullet?
          • Darin Jordan
            • 8335
            Both of his are the Bullets...
            • nate
              • 1652
              Will the Conversion kit work with the Angle drive, I suppose it should ....
              Im building a 28" WOF Tunnel now...
              I can't make up my mind but I like the Angle drive better, but im thinking the Bullet drive may be polished up.... shine haha!!
              LMT
              LehnerMotorenTechnik.com
              • sailr
                • Nov 2007
                • 6927
                The angled drive has a real techie look. I like it.
                Mini Cat Racing USA
                • properchopper
                  • 6968
                  I'm using the angle drive with the REK adaptor. Had to bore out the leg to allow the coupler to drop in - [lower CG than the all-metal adaptor.] The fin looked a little shallow so I modded it. Works great .
                  • nate
                    • 1652
                    Ill probably go with the Bullet drive, I wonder if any cutting will be required to the bullet drive with the conversion kit.
                    Propchopper what Coupler are you using?
                    LMT
                    • properchopper
                      • 6968
                      If you use the Hyperformance metal adaptor you wont have to bore out the leg. The composite REK sits lower, so you have to make room for the nose by boring out the leg. I'm using the Hyperformance coupler with the square-end shaft.
                      Go to YouTube, search "VS-1 with Ul-1". First vid had the drive accidentally a few degrees too high. Wheelie city
                      Search "VS-1 with UL-1 motor download two" for run with drive re-adjusted.
                      Both runs with my new Zippy 30C 4S 5000's.
                      • nate
                        • 1652
                        Whats the speed on this setup... What prop are you running again?
                        LMT
                        • properchopper
                          • 6968
                          No GPS on those runs, estimate close to/if not right at 50. Prop ia a Grimracer 42/55 de-tounged & mildly cupped. I may go for some more "cup", but right now the temps are so good [ due to the vertically high prop immersion/loading, allowing the motor to unwind] that I may leave things as they are. I set up my boats for heat racing, so all-out top speed takes a back seat to handling and longevity.
                          • Stealth Assassin
                            • 610
                            Sweet adapt with steering at HP and I have heard good things about the bullet drive from a top OB racer. Under rated
                            D
                            • bigwaveohs
                              • May 2009
                              • 535
                              OS 21 Lower Unit
                              Does anyone have any experience with the OS 21 XM lower unit adapted for FE? Will the Hyperperformance adapter work with the OS lower? Is the cable different (length & etc.) from say an HP cable?
                              I let the dogs out...
