Good Motor ESC & Servo Information
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3225
    You must have Excel installed to view these charts.
    Motors.zip
    BrushlessESC.zip
    Servos.zip
  • sailr
    • Nov 2007
    • 6927
    Good stuff! Man you spent a LOT of time putting this all together. Thanks!!
    Mini Cat Racing USA
    www.minicatracingusa.com
    • Meniscus
      • Jul 2008
      • 3225
      Thanks sailr. I pulled several sources to compile, so I don't deserve all of the credit.
      And I know it's incomplete! But I figure it can't ever be completely done with the FE sport continuing to grow.
      • Joern Markset
        • Jan 2009
        • 185
        What NEU series will be equal to Feigao 540XL series?
        Joern Markset
        Fokus Racing
        • Boatman
          • Jan 2008
          • 796
          I was told a Neu 1509 series can do anything a XL motor can do.
          • andym
            More Go Than Show Prop Co
            • 2406
            I would say a 1512 myself. The new 580L that Steve has is a strong mill and for the money better than a 1515. Just my opinion that means nothing but there you go.
            • richard templeman
              • Feb 2010
              • 9
              can some haple i have a 35in cat i have feigo 540 9xl with a hydra 120 i whant to see what prop i can use with that.
              thanks
              • Meniscus
                • Jul 2008
                • 3225
                Richard, to start with, have you tried this link? http://www.offshoreelectrics.com/conversion.htm
                It will give you a good idea of what to expect. The best way to determine what prop works for you is to start small and work your way up, only running the boat for 20-30 seconds at a time. That gives you the opportunity to check for heat. There are more detailed instructions you can read here: http://www.offshoreelectrics.com/propeller-chart.php
                To allow other forum members to weigh in about prop recommendations, you'll find you will receive much better information if you include more information about the hull such as manufacturer info and post pictures if you can. Also, it's really tough to make a recommendation until we know what batteries you are planning to use with this setup. That ultimately determines how many RPM's the prop will turn.
                If you include this info, you'll find more people will feel comfortable sharing some of their experience.
                Welcome to the forum!
