Blueprinting Tutorial
  • BHChieftain
    Fast Electric Addict
    • 1969
    Hi,
    I put together a tutorial on blueprinting, videos are located here:
    This covers strut, rudder, and blueprinting, it's for the Miss Geico/Blackjack but applicable for any cat.
    Chief
  • skeeler
    • Jul 2007
    • 198
    Those are very useful videos. Thanks.
    Does a similar approach work for mono-hulls?
    Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
    '09 Miata.
    Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
    • BHChieftain
      • 1969
      I've never had to "blueprint" a mono hull, but if you had any damage to the bottom of the hull the marine epoxy putty would be great for repair.
      Chief
      • bikergreen
        • Jul 2012
        • 422
        I have always wondered about the right process for this, I'm sure I could sort it out but who knows what the end result would be. Awesome you took the time to put this together!
        Thanks!
        • revoltrunner
          • May 2014
          • 646
          Thanks it really helped my MG
          • TRUCKPULL
            • 2971
            James
            Could you give us some information on the side to side profile for the cat sponsons??
            What Degree angle ( Dihedral) on the sponsons for Offshore racing??
            Should there be a difference in the angle of the left and right sponson the same as on a sport hydro for Oval racing??
            Larry
            • boilo56
              • Aug 2014
              • 390
              Hi, i would like to know if it is possible to blueprint this kind of ride pads and how please:IMG_20150719_215323.jpgIMG_20150719_215409.jpgIMG_20150719_215414.jpg
              Thank you!
              • Beaux
                • Dec 2015
                • 550
                Hi Chietain, I,m new to the hobby but not to boats. I just did this to mine,it,s a f1 hornet and the sponsons look so much better and sharper it really hooks in the corners now. I,m running A 3650 2930kv, it is running 50ish. Thanks again.
                • ray schrauwen
                  • 9471
                  Mine is rocking, I'll need to redo it. Need some marine Rx too. Wish I saw this long ago. Thanks Chief !
                  Nortavlag Bulc
                  • Beaux
                    • Dec 2015
                    • 550
                    I used fiber glass resin and tape on mine. It took about 3 passes to get a good shrp corner.
                    • ray schrauwen
                      • 9471
                      Could not find marine Rx on eBay just marinetex.
                      Nortavlag Bulc
                      • dmitry100
                        • Mar 2015
                        • 1264
                        Would making your ride pad edges as sharp as possible (and ride pads even) make a big difference in terms of speed for SAW?
                        I think my Mystic has a rather thick gel coat which I think resulted in "round" or "dull" edges around the ride pads... and the gel coat on the ride pads seem to have this unevenness to them like there is high and low points in there.
                        Can this unevenness affect speed as well? or is it more to do with overall stability, lift, etc...
                        • TRUCKPULL
                          • 2971
                          Ray
                          Marine Rx and marinetex are the same thing.
                          One is a West Marine brand name.
                          The other is the same thing from the company that makes it and sells it to West Marine.
                          I get mine at my local marina - store.
                          Larry
                          • dmitry100
                            • Mar 2015
                            • 1264
                            Wouldn't it work to just even out the ride pads by sanding the initial layer of gel coat?
                            Not sure what MarineRX is to be used for in that case...
                            • rdcracer
                              • Jan 2014
                              • 306
                              I my case when I did my Blackjack 29 the rear pad was concave. I would have had to remove too much material to get it level. It also builds up the edges so you can get rid of the rounded edges and sand sharp. It made an incredible difference in handling to mine.
                              Blackjack 29. Deltaforce 33. Cheetah twin, Insane FE30
                              1/10 1970 PaynPak, Aeromarine Jersey Skiff
