How do you reinforce hull?
  • petej
    • Jun 2010
    • 147
    Are there any techniques to reinforce a cat hull to prevent the top-deck from separating from the bottom section, where the two were originally, glued?
    I have an HK Genesis and a CF Zonda cat that I would like to strengthen and protect against the a fore mentioned separation.
    Pete
    Pete
    Motley Crew, Impulse 31, Zonda Cat, Genesis, Aqua Rider tug, E-Revo Brushless, Slash4x4
    Lay 1" fiberglass tape along the seam from the inside as far as you can reach. Use epoxy finishing resin to apply, using a 1" paint brush.
    • petej
      • Jun 2010
      • 147
      Thanks.
      Pete
        Or carbon fiber tape
        • readyfireaim
          • Oct 2014
          • 57
          So it's as simple as buying some CF tape like this?
          Use an epoxy like a 2 part 30 min and saturate the tape to the hull?
          Could you use this to reinforce a plastic canopy as well?
          • olwarbirds
            Magic Smoke Wizard
            • Oct 2012
            • 1136
            This would be better http://www.carbonfiberglass.com/comp...pe-Yard-2.html ... I would thin that epoxy with denatured alcohol or use z-poxy finishing resin...be careful what adhesives you use on that plastic canopy, yes you can use cf but I would buy a bigger piece and cutout enough to cover it all in one piece...I use 3M spray adhesive to tack the cloth in place then saturate
