1Y = 1 turn of windings terminated with Wye wiring pattern
1.5D = 1.5 Turns terminated with a Delta wiring pattern
8L vs 12L is only a difference of number of turns for the motor. Both motors will handle the same amount of output watts. Thus both are equally as powerful. Select the best winding based on the amount of voltage you plan to use.
The 1527 is more powerful than the 1521 as it is a larger motor can. It will dissipate more waste energy and output more mechanical energy when setup correctly.
Ryan
Ryan
