Blueprinting UL-1 Motor Wires
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /Mono -
Like I said in an earlier post, I am not ready to throw in the towel on the limited motors. Unless a well thought out and unanimus solution would be found. I plan to keep racing the 2030 and the 1800 while pushing them to the limit while finding ways to make them work. "Set Up"
One thing is for sure. While we are not all that happy about the quality and the risk of failure with these motors, they have held our heat racing speeds down in the 40-50 mph area. This has allowed us to bump, hit bouy's and fly off without distroying our boats. I still remember the days of running full blown 2P 4S open classes and watching guy's go home from a race with $1,000's of dollars of damage. Myself included. Right now Sean and I can run each other over and still take our boats home. :)
I would be afraid now that a change to a better quality motor would increase our speeds into the danger area again. We would most certainly have to spec a lower KV motor to off set the quality factor. Then what did we gain? Not sure I could by into the prop diameter requirement as of yet. Need to think on that one.Last edited by DPeterson; 09-14-2013, 10:27 PM.Comment
Chille
Yep - these were designed for rtr toy boats for the purpose of selling to the masses for a profit. We made a decision to incorporate them into our race boats. Of course I think the confusion still exists whether these classes were supposed to be rtr, beginners classes or actually an extension of the old 700 spec classes.
Darin
The boat racing started with 05 motors and then we evolved with the Astro Flight, Plettenberg and then the drill motors. Not a lot of choices available when the spec classes were developed. When the P-Limited motors were selected we were already running many varieties of good quality proven brushless motors. Lehners, Hackers, Aveox and many more. I guess the thinking/confusion again was that rtr/beginners will grow the sport. This is highly debatable of course as I have seen many beginners start and quit as much as I have seen nitro races converting to electric (not because of the spec motor but because of the speeds they see).
Side note - I am still learning more about the Gas classes (running a Thunderboat), but I am not seeing the gas guys speccing the lowest quality rtr motor they can get their hands on.
Mike Caruso - what do you mean by coating the motor wires?
Back to the subject of cooling - Cooling is absolutely needed where ever you can provide it. For the most part we can cool the can and the end bells which in turn cools the magnets. The heat is generated in the windings. Our cooling has little to no impact on the windings. So what to do? - keep timing down, prop down, set boat up to run loose and get rid of all un-necessary prop area.
My horse got back up for a few minutes - going outside now to beat him back down. :)
A Peterson Sighting in Wisconsin:
Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
Chille
Yep - these were designed for rtr toy boats for the purpose of selling to the masses for a profit. We made a decision to incorporate them into our race boats. Of course I think the confusion still exists whether these classes were supposed to be rtr, beginners classes or actually an extension of the old 700 spec classes.Mike Chirillo
www.capitolrcmodelboats.com
Prop choice (work) is key with these set ups. Just a little cutting, reducing, etc. can go a long way in reducing motor temps. Free up some rpms and watch the temps fall.
No matter what our means of attempting to cool the stators, a 1hp motor isn't going to pull a 2hp load for any length of time.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
Think of this. If we spec'd the props and used for example Leopard 4074/2200kv motors....They would last forever. (yes they are more watts than the AQ Motors but if we spec say x445 props or equivalent (h5 or 4555) We could easily run 120 amp seakings or equivalent esc all day only pulling 80 to 90 amps.
Just a thought.....Comment
Got anything in mind for the Tunnel guys? I'd hate to be the one to tell the tunnel heads on IW!! LOLMike Chirillo
I run a 447 and a 1800 kv in my limited cat. I was able to his 45.6 mph as verified only by Tony's GPS. Our last race tony and Stephen ran 2030's. they started with 42 and were a tad slower then me then. Stephen went to a 445. His boat was fast. Running loose and on the ragged edge but fast. One heat he lead for 5 and a half laps when suddenly he was dead in the water at the exit of turn 2. Brought the motor back in to find melted heat shrink and touching wires where they exit the end bell.
As for the limited hydros well I can't say. I've moved on but too much thought on the event is just depressing. My plans were to run a 1800 kv PB in that as well but I never got to do any testing on it.
Now on to changing spec motors. Run full blown p then, convince those in your club it's better and go with it. What was discovered here in D19 is that a castle or Neu 15151y ( common p motor) in a FE 30 makes it too fast to stay wet side down in race chop resulting in more dnfs then deck to deck racing or even finishing a heat. As I'm sure we all know you have to finish the race to win. In addition the extra speed you can squeeze out of the leopard 2200 kvs means more damage in a crash or blow off.
The way I see it there are 2 options, run the class get the set up right and be positive about it. Or find anything and everything to complain about and be a negative nancy I hate life kind of person.
The only problems with the class are the ones we make.Comment
As we've shown, and discussed at length over the years... spec'ing props doesn't solve anything... Those that can tweak will and game over. Plus, different hulls require different props... You'd turn a LIMITED (not "spec'd) motor class into a Limited Hull Class... Sounds a lot like Spec SV27 to me...
Racing is going to be racing, regardless of the motor used. There isn't a magic bullet, outside of spec'ing an entire boat system, that will prevent some from succeeding, some failing, some equipment surviving, and some not... Doug had it just right... just a LITTLE bit of time spent learing to tune a boat will go a long ways. People talk about how hard we are on equipment "out west here"... yet, I can't recall a motor being sacrificed yet, especially in the name of a trophy. My P-Ltd OPC Lynx, which has proven to be "pretty fast", draws right around 85-95 Amps... comes in after a 1-Mile heat, running 15-second lap times (NAMBA 6-Lap record setter Twice this year with a 1:30.6, and just last week with a 1:28.44) at right around 110-degrees... Running a 42x55 on a UL-1 motor.
Racing is racing... and the P-Limited classes continue to have high participation. SOMETHING must be right about the formula...
Oh, and the whole "beginners class" is a complete misnomer... It's a limited class, from and equipment perspective, so it's more "beginner friendly", but I don't think the general intent was for it to be for beginners only. It's a way for EVERYONE to compete on a more restricted playing field. That's it.Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
See I learned today that the heat comes from the Stator. Since the stator heat is blocked from the case with one of the worlds best insulators AIR. We can only deal with the heat that makes it to the case and end plates. Great motors none the less.Do It Like You Mean It .....or Don't BotherComment
Actually, you might be pleasantly surprised at how much a simple fan blowing some air though the endbell can help. We have pretty stagnent air inside our boats. Circulating it around a bit does help. Every little bit helps...
I was having some issues at a SAW event with the wires between the motor and the ESC on one of my 1-Cell hydro setups (pulling 150+amps through a ROAR 540 motor... 3.5 Turn, if I recall).... I added a cooling fan from a Castle ESC and the problem went away...
The old 700 brushed motors used to have fans built in. Some Neus can be ordered with internal fans as well. A simple 5V can blowing air into the endbell helps to at least move the heat out. In fact... my good buddy, Tony H. revitalized this idea at the 2012 Nats... even loaned me one of his fans! :)Darin E. Jordan - Renton, WA
Darin,
Thanks I never would have thought of using a fan. But as you proved just moving the air around caused a drop in temp simple fast easy. That is a speed secret guys not many are ever giving out. Thank you again.
MikeDo It Like You Mean It .....or Don't BotherComment
I like the ARC 36-55-1850kv motor. For $94 it's far more robust than any other 36-55 size motor in it's price range. The wire inside is at least 3-4 times the diameter of AQ motors if not larger and all are "y" winds. I've read all above, seems like it will stay the same. I'm all for p-sport then I guess but, not many around me interested yet.... We'll see what the next season has in store for us.
Darin, I had no idea that a certain motor either 1800kv or 2030kv would work differently in different hulls. I guess I just don't get enough pond time.
What motor and prop is best suggested for the PTSS hull then?? That said I just don't have the pond time to tinker with props nearly as much as a hard core racer would, that's my problem along with sore hands from arthritis.Nortavlag Bulc
The best luck I've had with the 2030 motor in this boat was with a tweaked X440/3 blade.Darin E. Jordan - Renton, WA
