Wow, didnt mean to stir this up LOL. Was just stating what I had heard a few years ago from some smart people on this forum and other places. Oh well whatever works for ya. Have a good day. Will
Best water pick-up ever!
there is no question about it, don is right. if water flows through the system to fast it can not absorb the heat. everything is designed with a optimal opperating tempature, determined by tolerances. just because the water coming out and the outside can of a FE motor is cooler does not mean the internals are colder. it is possable to cool the outside can so fast that the rotor and stator do not have a chance to transfer maximum heat to that can. when you check the tempature of the motor it may be cooler in places (outer can) but the internals can verry well be hoter.
also, yes you can blow lines even at slower speeds. i know this from experience and none of my boats are faster than 62-63mph and i dont restrict the flow other than by the size of the lines and water outlets.see my fleet: http://forums.offshoreelectrics.com/...hp?albumid=294
Hello!
An water pickup that drives alot of water trough the cooling tubes is awesome, altough, mine opinion is that you have to get the correct placement for it!
I putted mine near the keel of mine DF35 and tried everything to trim the boat up...weeks after weeks....It was chine waliking a lot and dindn´t have a sable behaviour..after 2 months i thought...What a a hel...let me try taking off the water pick up......I couldn´t don anything more to trim the boat...i tried everything....
The boat behaviour was from water to wine... :D
The issue is...look where you put it...
regardsComment
When things slow down for me I'm going to build a suitable water cooled heat exchanger, fire up a 30,000 BTU torch and a video camera, and put this to bed.LOL
Do you want to make coffee, or do you want to cool your componets?? Think about it.
The absolute bottom line is this. If you can't get adequate cooling by means of what we consider standard water cooling, your boat has the wrong set up, it is poorly set up, or you are running the wrong prop.
Just my .02 till I have more time.
Hang tough fellas!!
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
Heat from components needs time to dissipate into the water (thermal exchange) inorder to properly cool the component. This is done by utilizing a bigger bore tubing, slows water rate down when entering the component then back to a smaller diameter bore tubing to quickly evacuate the thermally heated water.HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:Comment
Bingo!
I run the stock cooling on my SV's with a bigger hole in the rudder pickup and I get much more flow out of the system, and get this I can run any prop I want and my temps never get above 125* no matter what and usually hand at 110* and lower
I think some are over thinking this.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Westbeach has hit the nail on the head.
The photo shows the three cross holes in the plate about to be re attached to the ESC
Cheers.
Paul.Attached FilesSee the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Hello Guys,
just want to join the discussion. First a few words about myself. I've been studying mechanical engineering for 5 years now and topically making my masters degree. Within these 5 years I also learned a lot concerning this topic due to lectures in thermo and fluid dynamics as well as heat exchange.
Therefore I can say, the more water flow, the better it is. The idea of slow water because it needs time to heat up is just a so-called hoax. So I think limitation should only be a choice when the pressure gets too high that the flexible hoses get off even if they are already secured.
And as I also run several FE quite fast FE boats for several years now I can say, the experience approved the theory. So my statement: The more - the better.
If interested I might try to explain the theory behind it with an easy explanation.
Best regards,
ManuelComment
I'am with Manuel:
I am a degreed engineer (for 35 years now) at an industrial plant.
One of my projects was to design a $1,000,000 cooling system for our process.
It involved many large heat exchangers.
This project gave me an oppertunity to study heat transfer.
All the principals involved are exactly the same as cooling an RC motor.
I am absolutely sure that more water cools better.
I am absolutely sure: the faster the water flows the better.
Slowing down the water flow will result in a hotter motor.
MarkLast edited by mm123521; 02-06-2011, 08:35 PM.Avatar is the dangerous end of a Gatling Gun!Comment
