Powering a 1/8 Unlimited
  • TLH101
    • May 2016
    • 60
    Will a 4074 2250kv with 130a esc run a 1/8 hydro on 4-6s?
  • Bande1
    • Mar 2023
    • 684
    1/8th scale is usually around 44 inches. just to be clear we are on the same page. a 4074 is wildly undersized. a 4092 would be the absolute bare minimum. the appropriate motor would be a 5692-56112 on 8s. max KV would be around 1250kv, with 900kv-1100kv being ideal. ESC minimum should be a ZTW 200A. Ideally a Castle Creations XLX2.
    a TP 4070 with a flycolor 150A/OSE Raider 150 on 6s could possibly suffice for speeds up to about 50mph.
    • oscarel
      • Dec 2009
      • 2130
      With limited info the short answer is yes. A rubber band powered paddle wheel will as well.
      Sent from my SM-S908U using Tapatalk
      • tbonemcniel
        • Sep 2020
        • 296
        Yes, but not very fast.
        If it's for sport boating, I would recommend a 56mm motor around 800-1100 kv on 8S paired with a 300+A ESC. ZTW, SF, Castle, etc. Can't go wrong with an XLX2 for 8S or less. Less kv for more voltage.
        If it's to be NAMBA race legal, then the motor cannot exceed 42x105mm or 860kv rating. So a TP4070 860kv or Neu 1527 850kv would be good options. Also paired with a 300+A ESC. ZTW, SF, Castle, etc. Can't go wrong with an XLX2 since this class is 8S and so is the ESC.
