44? Areomarine hydro
  • donzi65
    • Nov 2019
    • 28
    What brushless motor setup would you recommend not racing but would like it fast 50 mph if possible what do you guys suggest
    • 8012
    Which AM hydro? Is it new or already set up as a gas boat? What experience do you have building FE boats?
    • donzi65
      • Nov 2019
      • 28
      Not sure of the name of hull but it?s never been built and I have run and built nitro boats not too much experience with brushless
        • 8012
        A photo or two of the hull would be helpful. AM made several different designs.
        • Chrisk7
          • Dec 2015
          • 38
          I have a 48" ML Boatworks mono that I took the 30cc modified Gizmo engine out of and installed an SSS 56123 700kv motor, Seal 300a ESC, and I'm running on 12s so I can use the same props that I used for the gas engine. It runs the same speed and a little faster on electric. Around 65 mph.
          On this FE setup the motor and esc don't hardly even get warm so I'm sure it's a bit overkill but I haven't checked the logs yet either.
          My batteries are pretty worn out from years of heli use so I imagine new batteries in the 5000 to 7000 mAh range would make a ton of difference.
