Rudder VS turnfin
  • Vin-m
    • May 2014
    • 308
    Rudder VS turnfin
    Can someone clarify if it makes a difference what side the rudder goes on VS the turn fin and why? Like if the turn fin is on the right side does the rudder go on the right of the strut?
  • fweasel
    master of some
    • Jul 2016
    • 4286
    Rudder goes to the right of the prop if you're going to be running clockwise circles, i.e. Right hand turns. Turn fins are most often installed in pairs, but I suppose only one side would be necessary if you were going to turn in just one direction for racing.
    Vac-U-Tug Jr (13mph)
    • Vin-m
      • May 2014
      • 308
      It's for a 1/8 hydro
      • Luck as a Constant
        Make Total Destroy
        • Mar 2014
        • 1952
        It doesn’t really matter on a hydro, but since they’re right turn, I put the rudder to the right of the strut because the rudder will always be turned away from the prop and I don’t need to worry about clearance. If you mount to the left, rudder will turn towards the prop and you may find larger props won’t have clearance when the rudder is turned. Make sense?
        • Vin-m
          • May 2014
          • 308
          Very clear thanks
          • fweasel
            master of some
            • Jul 2016
            • 4286
            Missed that, sorry. I agree, prop clearance would be my primary concern about mounting it anywhere by the right side.
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              Vin-m.
              Here is a bit of info that explains most of the effects of rudder & turn fin placement & adjustment. It's what I used when I first started setting up Hydros all those years ago. And still do.
              http://www.modelgasboats.com/resources/tuning
              Here's an old thread on the topic too which will shed some more light on the topic.
              https://forums.offshoreelectrics.com...os-amp-riggers
