Old Shovel issues
    • 7673
    Old Shovel issues
    To the scale guys, what dang prop do you run on these?
    I have been working my way thru my smaller props on this boat https://forums.offshoreelectrics.com...=Miss+Cadillac
    Last prop was a cut up 440(37mm) with a bunch of mod work.
    It was good till about 2/3-3/4 throttle then it tosses the back end up.
    Next and last prop I have is a 438 cut to 35mm and detounged.
    I am not expecting a go fast boat as we are trying to run at the city park.
    Thanks, Shawn
  • JimClark
    • 5907
    Well with the proboat 1500kv motor a X447 work well I have never run the motor you have but I am thinking maybe a 42 or 45? I looked at your other thread can you tell me how deep the sponsons are and how deep your prop is? Also what does this boat weigh RTR?
    Billy Graham
      • 7673
      Thanks Jim, I’ll check on this when home in an hour or so.
      It is light, at least by my standards
        • 7673
        The sponsons are 1 1/4” deep as is the hub of the prop. Well more like 1 1/4” at rear of of hub.
        RTR weight is 97 oz with a 4200mah 4s pack.
        Pretty sure it is an 1800kv motor
          I’m confused, a UL-1 motor is 2030 Kv not 1800. If the transom is hopping then either the prop has too much lift/down angle/too deep or the CG is too far forward. A Kv of 1800 would work better with an x445.
          Beautiful boat BTW.
            • 7673
            And it is a gold can AQ motor of 1800 Kv
            I know these aren’t supposed to be fast
            Damn phone pics, haha. I have RTR CG 2 1/2” behind sponson trail edge.
            • JimClark
              • 5907
              CG should be closer to 1 inch behind the sponson's. Those sponsons are a little deep my boats have been more like 1 inch deep and the center of the drive dog also at 1 inch.
              Billy Graham
                • 7673
                Now that I measured the CG I would’ve thought it was a lot closer to the sponson edgebased on the behaviour
