Rebuild ‘67 Miss Bardahl
  • eric113
    • Sep 2011
    • 323
    I bought the hull off jevmax. From what he told me is that someone built it, ran it...esc fried taking everything with it. Then sold it, Jim bought it... it sat and then I bought it.
    Plans so far
    -RC boat company 1/8th scale roundnose hull
    -Speedmaster rudder -Ordered.
    -Zippkit large turn fin or maybe Mojo turnfin -Zippkit fin Ordered
    -ZTW 200a esc -Ordered
    -H.E.T. Typhoon 700-98 840kv motor -Ordered
    -Gaint power 2x 4s lipos
    -Scale motor
    -Misc hardware
    For whatever reason they left the brackets, but no rudder or turn fin? Ordered those and got them Installed.
  • eric113
    • Sep 2011
    • 323
    Next I cleaned the inside hull out. It still smelled like fried eletricronics, I let it air out for a few weeks. Then I started to wipe it down with denatured alcohol, there was nasty film all over the inside of the
    hull.
    Before
    After. Smells lot better too.
    I need to make a wedge and pick up some west marine epoxy for the stuffing tube, it long and unsupported.
    • Jesse J
      scale FE racer
      • Aug 2008
      • 7115
      "Look good doin' it"
      See the fleet
      • eric113
        • Sep 2011
        • 323
        While back got the rudder and turn fin mounted.
        I got the motor, and esc in.
        Today, spent time mounting the motor and getting the motor mount lined up perfect. I also got the thrust bearing and coupler installed.
        I also mocked up the esc. This where I need little help, the motor wires will reach but battery wires will not. Which wires would be best to make longer?
        • leonard feeback
          • 130
          Put the esc up by the motor and move the batteries under the deck and move servo to rudder up where shaft goes thru hull. Keep as much weight off strut and prop as possible.
          • jevmax
            Legend
            • Aug 2007
            • 368
            Looking good Eric. Looking forward to seeing her run!
            • eric113
              • Sep 2011
              • 323
              I hate to cut out the front where the batteries set now. I feel like it weaken the hull alot. It has cutout underneath for added floatation. So for now I going to try out the current layout.
              Thanks Jim.
              • CraigP
                • May 2017
                • 1464
                Great boat! That will be awesome to run! I recommend you cut about 1/2” off the stuffing tube at the coupler. I personally feel that longer motor wires are less detrimental than longer battery wires. The motor wires carry an AC current, the batt wires are DC. AC runs over wires easier than DC. Just one man’s opinion...
                • CraigP
                  • May 2017
                  • 1464
                  If you need to run longer batt wires, then install a cap Bank halfway thru the run to the ESC and be sure you got plenty of cap at the ESC. That will help decouple the AC ripple content on those DC wires. Please post pics, this was my favorite Unlimited! Billy Schumacher drove for my Dad’s boat, the Parco’s O-Ring Miss. we called him The Shu!
                  • CraigP
                    • May 2017
                    • 1464
                    Also, you might find that the shovel nose works better with a straight fin, set at about 15-20 degree of lean. The curved fins can suck that inside sponson too much. Easy to see when you get her out on the water.
                    • eric113
                      • Sep 2011
                      • 323
                      I do plan on cutting .5” off the stuffing tube. Everything is just mock up. If I leave the esc where it is I will have no choice but to extend the battery wires. Any recommendations on caps bank for 8s? If I do what Leonard suggested I would have to extend the motor wires. But I would have to cut on the hull to be able to move the batteries forward to front. Strengthen wise I don’t know, because it been cut out on the bottom for added floatation.
                      I will try out the turn fin that I have now, if doesn’t work I will find a straight blade fin.
                      • CraigP
                        • May 2017
                        • 1464
                        Ose has a heifi Cap Bank, listed as Product ID hef-h#0005
                        This will work great!
                        • eric113
                          • Sep 2011
                          • 323
                          Made a order to OSE, Progressive Rc, Mojo racing.
                          I got the cap bank that Craig recommended. I also ordered 10G wire, bullet connectors 6mm for the batteries and 8mm for motor. Got it all soldered up.
                          Soldered the 8mm bullets on the motor also. I cut down the stuffing tube. Made a wooden wedge for supporting the stuffing tube, just need to epoxy it in
                          It getting closer of being up and running.
                          I still need to get
                          - Scale motor
                          - Receiver
                          - Biggest expense... Lipos.
