Low friction underneath hull?
  • gabz17
    • Jan 2017
    • 24
    Hello to all, Is it possible to use some sort of tape or paint on our rc hydroplane hulls that makes it have lower friction on the water. Not sure what they use in H1 but I am curious? But in photo you see some kind of coating in black underneath.
    Sent from my SM-N920W8 using Tapatalk
  • fweasel
    master of some
    • Jul 2016
    • 4286
    The hydrodynamic science says a rougher surface on the bottom is faster. It induces the formation of micro bubbles in the water, which act like ball bearings and thus lowering surface tension between the hull and water. A smooth surface can actually create suction and therby increasing drag. Now, the degree to which this will actually affect a scale RC boat is up for debate to some degree. The physics behind it is solid, enough so that many will scuff the riding surfaces with sandpaper on a bias direction to the water flow across the hull and recommend against polishing or waxing the underside of a hull.
    Vac-U-Tug Jr (13mph)
    • pescador
      • May 2009
      • 499
      Maybe it was something like this? I guess it was a popular speed coat for hull bottoms but fairly toxic. Funny the ad even mentions r/c boats. I bought a spray can of it and tried it on the bottom of a Sport 40 about 10 years ago, it dries matt black with sort of a graphite feel.
      Sent from my iPad using Tapatalk
      Namba District 16
      • Meniscus
        Refuse the box exists!
        • Jul 2008
        • 3225
        Regarding fweasel's comment, many years ago now, I added ride pads to a sport hydro. Just for fun, I dripped some thin CA into the unfinished wood. The result was a very rough surface that felt very much like sandpaper. During testing, I couldn't point to any difference, even when swapped for smooth, finished ride pads. AOA, width, etc. was all the same between the two. I guess it might make a difference if it was on a lighter rigger. However, when setup correctly, there's so little surface in contact with the water, I can't imagine that it would make but so much of a difference.
        I did witness a larger mono with some 'slick' spray on the bottom. At SAW speeds and no other changes, once the 'slick' spray was applied, the model would blow-over. I've never tried any slick additive, so I couldn't say conclusively one way or the other.
          “Speed coats” have been used on FE boats for many years. The JAGs team used them on some of their earlier record-setting SAW boats. I did some testing on my own SAW boats years ago and found a small speed advantage - 5% on a 45 mph 5 volt boat - by painting sponsom bottoms with a epoxy/colloidal graphite mix. But the advantage may have been due more to the excessive sanding and blueprinting I had to do to the coated sponsons than the coating itself. I don’t know the effect on a hull with more wetted surface like a mono or cat.
          And while it is true that at speed very little of a hydro is in the water at speed, all model boats are wetted down in turns. This is where an effective speed coat would do the most good.
          • gabz17
            • Jan 2017
            • 24
            Thank you so much for all your input, truly appreciated it.
            • Tom G
              • Aug 2017
              • 57
              On the full size Miss Bud we used a graphite impregnated paint on all the running surfaces but it really never proved to be a of a significance benefit
              On my Scale hulls I just paint those surfaces black for appearance sake
              • Moonie
                • Jan 2014
                • 325
                At my local marina they use some stuff called sharkskin. I'm not sure if it works but maybe it's worth taking a look.
                Gold Spilo
                • Tom G
                  • Aug 2017
                  • 57
                  The biggest thing. You can do reduce drag is make sure that all the breaks in running surfaces ,sponson backs, hull steps, transom ect. have nice sharp edges. Any radius-ed edges will cause the water to roll off not break cleanly causing the hull to suck down in the water increasing drag
                  • Moonie
                    • Jan 2014
                    • 325
                    Tom I agree with what your saying 100% and it's the same method I use.
                    Gold Spilo
                      I was thinking about scuffing the bottom of a mono I have to test this theory. So let me ask you guys this. Would it be an accurate enough test if I ran the boat, checked the speed gps. Then bring the boat in. Top the batteries back off right then and there. Scuffed the bottom. Threw it back in and attempted to duplicate the same direction run as the first run. I can’t think of any other way to do it more accurate. Anyone interested?
                      • CraigP
                        • May 2017
                        • 1464
                        Sounds like a good A-B test to me. But I think that “shark skin” talked about earlier would be a more consistent texture. Scuffing them up will produce a rather random surface, don’t you think?
                          Well I was gonna use my Cnc scratcher. Just kidding. This is such on a small scale I’m not sure it matters
                            • 7673
                            I have noticed a difference on monos but never really tested it on cats. And the mono was just ‘seat of pants’ judgement on any benefit.
                            Try it out Travis. Lots swear by using the 400 grit on the bottom.
                              I feel like it helped my fast mono I had and my Rivercat. All my fastest boats have been scuffed.
