New 2004 Miss Budweiser T-6 Build
  • Tom G
    • Aug 2017
    • 57
    Basic :Spec’s
    1/8 Scale Hull is by RCBc All Carbon Fiber SG121-H running as 2004 Miss Budweiser T-6
    ESC: Alien Power Syst. 300 Amp on 8s 29.6 VDC
    Motor: NEU 1527 /1.5 /8mm on 8s & Water Jacket
    Motor Mount by HRC Mfg. 1527 floor mount
    Motor Coupler by MBP 8mm to ΒΌ
    Battery’s: 2ea Nano Tech 6000 Mah in Series for 8S 29.6 VDC
    All the running gear is From Acuu-Tech
    Authentic Scale Strut , Turn Fin , Rudder Bracket & Tapered single pick-up Rudder
    Prop's By ABC # H-2215 -19' rake -38BAR & #H-2315-17' rake-45 BAR 2 blade Cleavers, thinned, sharpened & balanced. by Me
    First Day of the build removed all the release agent ( pain in the BUTT) established the boats Center line, and mounted the rudder bracket and rear wing vertical stabilizer bracket
    MORE TO FOLLOW Next mount Turn Fin ,Strut ,stuffing box & motor[B][/B
    • 7673
    Nice, I have a sport hydro build coming up soon myself. Subscribed
    • K.R.Joye
      • Feb 2010
      • 1045
      Nice$$$
      ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
      ****2008/9 MMEU LSO, 2008 LSH CHAMP****
      ~~~~~~~70 MPH Club Member!~~~~~~~~~
      • Tom G
        • Aug 2017
        • 57
        Back to it the installed the turn fin, cut the hole and installed the strut. Roughly set the location for the Motor, battery’s and ESC to get a idea ware the C/G balance point will be .
        With battery’s located in the wells for fuel tanks in a nitro boat and the ESC placed in the bow’s forward radio box. The balance point is 3/4 TO 1 inch behind the rear of the sponson, which is close to the Newton Marines drawings c/g’s location
        Note : When U move the rudder to the left side of the hull the holes in the rudder pivot block are upside down.
        Instead of modifying the rudder. I took a chance and ordered the rudder pivot block for a Speed Master Turn Fin Bracket (they make both right & left hand pivot block’s) which by the way are identical to the Accu-Tech pivot block’s and fit perfectly .
        PROBLEM SOLVED :
        Motor mount holes drilled an motor installed. .
        Time to layout the locate and cut the hole for the stuffing box I always HATE this process TO EASY TO SCREW IT UP
        • CraigP
          • May 2017
          • 1464
          CG sounds perfect! Is this going to be 1/8 scale build?
          • Tom G
            • Aug 2017
            • 57
            Yes 1/8 Scale
              • 7673
              Have you established a finished weight yet Tom? I’m just curious for my build, I have a 2028 and a 1527 and still contemplating which to use. The Castle motor is waaaay heavier
              • centralrcmystic
                • May 2015
                • 245
                Perfect exactly what I’m looking for
                • Tom G
                  • Aug 2017
                  • 57
                  Screen Shot 2017-12-19 at 12.02.47 PM.jpg My 1/8 Nitro boat RCBC SG118-H 1994 Miss Bud T-3 hull weights 18 lbs RTR with Fuel
                  I'll probably get torched for mentioning a nitro boat on a FE site LOL
                  I think the FE boat might be a little heaver cause the Battery's & ESC weight more then the engine and exhaust system
                    • 7673
                    Originally posted by Tom G
                    [ATTACH=CONFIG]157301[/ATTACH] My 1/8 Nitro boat RCBC SG118-H 1994 Miss Bud T-3 hull weights 18 lbs RTR with Fuel
                    Oh man I’m shooting for 16lbs on my Edge Hydro. Or at least that is what I think I can pull off. I should be good with a 1527 or 1530 then.
                    • Doug Smock
                      Moderator
                      • 5272
                      LOL I think you'll be fine.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • Tom G
                        • Aug 2017
                        • 57
                        What scale Hydro are U building 1/10 1/12
                        good luck Hope U make 16 lbs
                        My bare hull is 6.5 lbs As it sits in pic with the motor & the of majority hardware is 7 lb 11 oz plus the battery's ESC 6 .7 lbs = 13.7 lbs not including the rest of the other peripherals ,cowls, wings and the rest of the electronics, paint ect:
                        • Tom G
                          • Aug 2017
                          • 57
                          The stuffing box hole has been cut & the tube fiber glass clothed & epoxy-ed into place
                          As soon as the epoxy cures I'll grind off the excess e-pucky off and cut the tube to length
                          More to follow
                          • Tom G
                            • Aug 2017
                            • 57
                            The stuffing box install and shaft alignment are done with mock up. I sure like the HRC Mfg motor mount made the prop shaft shaft alignment a snap.
                            If I hadn't screwed up the only piece of 5/16 tubing I have for the flex shaft while trying to arc it to align with the strut the drive line would've been finished .
                            Next try I'LL use the ole trick of packing it full of ultra fine sand and heat it slightly with a heat gun so it will no kink agn.
                            HOPEFULLY
                            If anyone has a Simpler way to bend the tubing I'm open to suggestions
                            • pescador
                              • May 2009
                              • 499
                              Steve has that covered :)
                              https://www.offshoreelectrics.com/bend-brass-tubing.php
                              Namba District 16
