Miss bud hull damage
  • fitzloff
    • May 2014
    • 66
    I had a mishap at the pond last weekend. I plan to rebuild. But looking for advice One of the local guys said to use silica filler? I am not familiar with it. How would you guys go about sealing this back up?
    Thanks guys!
  • Beaux
    • Dec 2015
    • 550
    Wow, that is a tough one. Gently cut out in a v shape on the outside cracks and shred up some fiber glass and start working it in.
    • zooma
      Local club FE racer
      • May 2014
      • 652
      I would mix chopped glass fibers into the epoxy. Silica (sometimes called micro-balloons) adds no strength, but it is easy to sand for surface repairs.
      Ron - The Villages, FL
      • Beaux
        • Dec 2015
        • 550
        The chopped glass would tie both sides of the repair together. Once it is cured make you a little block and cut it back down.If you wet sand it your paper will last longer.
        I picked up some 3\4 once fiber glass the other day it is paper thin and easy to work with. Once you made your repair you can put 2 or 3 strips over the repair.and block it back down.
        It's just gonna take some time .
        • CraigP
          • May 2017
          • 1464
          I would begin by opening up the seam cracks with a Dremel tool, using a cutting wheel. I would separate the two halves where the wood is cracked in the center section. The crack from the seam to the side of the sponson I would grind out, using a drum sanding wheel, take out the spider cracks then lay back in with the epoxy filled material as mentioned above. I wouldn’t use micro balloons, just not adding strength back in. As the others have mentioned, this is something you’re going to have to get geared up for... Take your time. I had to do a similar repair on my hydro, got the repair done, but still need to re-paint. Crashed it right after painting, pissed me off! I just needed to let it sit for a week while I got geared up for it.... You can do it!
            • 7673
            All good advice here. I have repaired many mishaps to date. It is not real hard but it takes time and perhaps patience. It’ll turn out good in the end. I do have the same hull here which will need similar strengthening when I get to it.
            One thing, just do your best to rough up any surface that you are bonding epoxy to. 80 grit works
            • Beaux
              • Dec 2015
              • 550
              Hey bud, just checking to see how your project was coming.
