Whip 40 slight twist. is it ok or not?
  • ray schrauwen
    • 9472
    I just checked my Whip 40 and when on the setup board there is a 2mm difference in height measuring from corian board to bottom of transom.
    Viewing from the rear the right/starboard side is higher.
    What problems will this cause?
    I don't think it's fixable since it most likely occurred when I fixed the transom.
    Advice please, thanks!
    Nortavlag Bulc
  • TRUCKPULL
    • 2969
    Seeing that the rear end rides up on the prop, and the transom rides in the wind.
    It may be hard to see a difference when running.
    Larry
    • 785boats
      Wet Track Racing
      • Nov 2008
      • 3169
      I would just check that the rudder is at 90 degrees to the set up board (when viewed from behind) & not the bottom of the transom, and adjust accordingly.
      • ray schrauwen
        • 9472
        Thank you!
        Nortavlag Bulc
        • longballlumber
          • 3132
          Are your ride surfaces OK when setting on the setup board? Do they measure correctly with an digital angle finder???
          Regardless, a twist in a hull is never optimal. Whichever corner on the transom is lifted; the opposite sponson is going to be "tweaked". This WILL affect AOA, Dihedrial, etc... How much of a performance difference???? Only you will know. 2mm isn't much, but I am surprised only the transom caused this. "Usually" the upper and lower decking will lock in hull rigidity, but who knows.
          good luck,
          Ball
          • ray schrauwen
            • 9472
            They seem ok. I'll try to check with digital angle gauge.
            I wasn't going to seriously keep running Q sport since its more $$$ than I can handle upkeep. Rather just run 4s boats.
            I'll just run it one more season and then retire it.
            Nortavlag Bulc
            • ray schrauwen
              • 9472
              The biggest problem with my Q sport was heat and I think I found the choke point for cooling.
              Nortavlag Bulc
