ML Boatworks RSX310 , My 1st Outrigger design ever! 31", P/ P-ltd FE Rigger!
  • cybercrxt
    • 2909
    #256
    Finally, a full instruction manual for the RSX series is done! Email me for a copy anyone that needs one!
    • ray schrauwen
      • 9472
      #257
      Can someone advise me on the size of bolts used to secure the sponsons to the booms?
      Someone said they used 2mm bolts and tapped the carbon rod. I don't have any 2mm bolts around and not enough 2-56 bolts.
      Nortavlag Bulc
      • Moonie
        • Jan 2014
        • 325
        #258
        Ray Someone ment to say 3/32 not 2mm. I hope that helps you.
        Gold Spilo
        • TRUCKPULL
          • 2969
          #259
          A #4 is 7/64" or 2.8mm
          A #2 is 2.1mm
          So what size bolt is 3/32" ??
          Larry
          • ray schrauwen
            • 9472
            #260
            I'll see what I can find at local vendors.
            Thanks
            Nortavlag Bulc
            • mojoracer
              • Sep 2010
              • 613
              #261
              Finished Product!
              Bob Zola NAMBA 212
              2022 NAMBA Nationals FE High Points Champion
              Owner www.mojoracingproducts.comTeam Driver: Black Pearl Hydroplanes
              • ray schrauwen
                • 9472
                #262
                Nice work Bob!
                Nortavlag Bulc
                • RayR
                  @SiestaKey.calm
                  • Jun 2007
                  • 1518
                  #263
                  My take on the RSX310
                    • 9488
                    #264
                    That is sweet!
                    • Steven Vaccaro
                      • 8723
                      #265
                      Ray that looks great.
                      • ray schrauwen
                        • 9472
                        #266
                        Originally posted by mojoracer
                        Here ya go Ray. No Mojo speed secrets on this one..... Tube was easy and gentile bend. Motor mount is a raffle prize I picked up along the way (and OSE sells them too). I put the mount in with Epoxy and pop rivets from underneath. I also added 1/8th plywood to the tub floor in the motor area. I did shim the mount to get more angle. I set the motor to clear a TP 4060 if need be, but probably will run the little NEU motor for P. I also re-did the 5/16th tube after the photo to get better flex alignment. Using Speedmaster small extended strut and mini rudder. Rudder and strut brackets are tight together. I am using a Castle modified airplane ESC that Mr. Buaas did for me. Battery options I am looking at are a single 4S 6000 or pair of 4S 3300s (tight fit)! Will probably run a single 4S 5000 for limited set up. Enough room in the tub for multiple battery configurations!
                        I wonder how much you shimmed the front of motor mount?
                        Hello Bob! lol... Yeah, still not done but I just need to rig and paint.
                        Nortavlag Bulc
                        • mojoracer
                          • Sep 2010
                          • 613
                          #267
                          Looks like 1/8" plywood Ray.
                          Bob Zola NAMBA 212
                          • ray schrauwen
                            • 9472
                            #268
                            Thanks Bob. Your rudder mount overhangs a bit on starboard side I guess???
                            Nortavlag Bulc
