Good Morning Paul and Don.....
I certainly appreciate the information. I'm thinking the sheeting for this particular boat is the way you did it Don. I know Mike (ML Boats) was saying to just sheet it in 2 separate halfs which made sense for some hull integerity where the sponson's meet the center section. But Don, you have not seen any problem with that part of the boat.....so I'm thinking the epoxy bond that is made between the sponsons and the center section must be plenty for this boat. It certianly will be easier in that area of the center section where the sheeting meets up with the formed airfoil blocks up front.
Paul...I can see that sheeting process working out well on a Sport 20 or 40 boat. I have my eye on that new GSX380 that Mike is putting out....LOL
So Don, You don't see there being any problem with that ETTI ESC where I blew through the top of the heat sink do ya? Thought for sure I'd get something back on that goof up....LOL (Even a "Way to go"
....LOL) One other question Don, Did you make a hatch plate for the very front nose section to keep things water tight or did you just tape that section of the cockpit cowling between the cowling and the ply framework????
Put in my order for all the primer, paint and clearcoat material. Went through Coast Airbrush in CA. Seemed to be the best place to go for smaller quanties of HOK paints. They have been real helpful also on painting sequence , coverages and taping methods. There is one thing though....THIS STUFF IS NOT CHEAP!!!!.........LOL
But it should look really great when its done. It will definilty be testing my painting skills.
Well thanks again guys....Back to work.
Mike
Mike
