1/8 Scale hydroplane turn left set up
  • icemanxo
    • Sep 2013
    • 108
    Hello,
    I was wanting to set up a 1/8 scale hydroplane to turn left and wanted a reliable setup that I can count on so I don't need to break any speed records plus this is not to race in any club. I need help with esc, motor, right hand prop suggestions. I also was going to use 8s setup or any other input would help thanks for looking.
    To be clear, you want to run counterclockwise ovals, right? What hull do you have? What are your speed and run time goals? What is your budget?
    • icemanxo
      • Sep 2013
      • 108
      Correct I'm going to run counterclockwise and was going to order rc boat company hull T-6. I wanted a little more run time than speed (45mph to 50mph) and budget is open. Thanks for replying
      • icemanxo
        • Sep 2013
        • 108
        Scorpion 4035-800 brushless motor I was looking at this motor any thoughts about this
        • icemanxo
          • Sep 2013
          • 108
          Magnet Poles 8
          Motor Wind 6 Turn Delta
          Motor Wire 27 - Strand 0.29mm
          Motor Kv 800KV RPM / Volt
          No-Load Current (IO) 2.5 Amps @ 8.4v
          Motor Resistance (RM) 0.010 Ohms
          Max Continuous Current 100 Amps
          Max Continuous Power 4200 Watts
          Weight 435 Grams (15.34 oz)
          Scorpion 4035
          • jwray
            • May 2012
            • 9
            Something to think about is finding a turn fin that is cuped on the right side and you may have to reshape the bottoms of the sponsons to get the boat to slide in turns unless the company will mold the hull for counter clockwise running.
            • icemanxo
              • Sep 2013
              • 108
              Thanks for the details
              • icemanxo
                • Sep 2013
                • 108
                Any suggestions on lipo setup like c rating and 6s, or 8s etc
                • JimClark
                  • 5907
                  8 to 10 S and I would think at the very least 35c (quality cells)
                  Billy Graham
                  • icemanxo
                    • Sep 2013
                    • 108
                    Should I use 1 or 2 packs
                    • JimClark
                      • 5907
                      Dont know if a single pack will fit in your boat. My guess is two would work better for weight distribution
                      Sent from my SGH-T989 using Tapatalk 4
                      Billy Graham
                      • icemanxo
                        • Sep 2013
                        • 108
                        How many mih for total battery capacity
                        • icemanxo
                          • Sep 2013
                          • 108
                          How much total battery mah capacity should I use and any prop suggestions or esc
                          • mojoracer
                            • Sep 2010
                            • 613
                            I have a Scorpion and it pushes my 19 lb PAy N Pak 60 MPH on 10S
                            Bob Zola NAMBA 212
                            2022 NAMBA Nationals FE High Points Champion
                            Owner www.mojoracingproducts.comTeam Driver: Black Pearl Hydroplanes
                            • icemanxo
                              • Sep 2013
                              • 108
                              How many mah are you running on the battery's thanks
