G. Finlay 1/16th scale Hydro
  • billf1973
    • Feb 2011
    • 127
    Hello,
    I am having a hard time getting my hydroplane to run correctly. It is powerd by a 3300kv, Esc is a seaking 90amp, Prop is a 1.34x2.06, and a 2s 3300mAh 30c lipo. The boat wants to go, but when full throttle is applied the front of the boat dives down. I have lowered the stuffing box about a 1/4in since it was level with transom. Still get the same result. Any help would be Great.
    Thanks,
    Bill
    JAE 45 FE, DF Vortex 24, PB Mystic, Aeromarine Sprint Cat 42, Aeromarine Sprint Cat 36
  • Diegoboy
    • Mar 2007
    • 7244
    can you post a transom pic?
    • billf1973
      • Feb 2011
      • 127
      Diegoboy,
      Here are a few pics of the transom.
      Thanks,
      Bill
      • Diegoboy
        • Mar 2007
        • 7244
        How much strut angle is there + or - ? Where's the center of gravity? and What size prop is that?
        • billf1973
          • Feb 2011
          • 127
          Not sure of angle. I know it is about 1/4 inch between stuffing box and bottom of hull. CoG is up in front of motor where lipo goes, and its a 35mm prop.
          • Diegoboy
            • Mar 2007
            • 7244
            Can you take a profile picture of the transom please?
            • billf1973
              • Feb 2011
              • 127
              That is 1/4 inches down at transom.
              • Diegoboy
                • Mar 2007
                • 7244
                Originally posted by modelpowerboat.com
                Strut angle: A strut has a positive angle when the prop shaft points upwards, far from the water surface. In this situation, the transom is pressed down. A negative angle occurs when the prop shaft points down, towards the water surface, raising the transom. If you imagine the boat supported on a transverse shaft that goes exactly through the CG, it's easy understand that, when the transom is lowered the bow goes up, reducing the wet area. The contrary occurs with a negative angle for the strut. Although apparently we could use the strut angle to correct any incorrect attitude, the truth is that the neutral angle is the ideal, just a few degrees off are allowed to adjust the wet area. If more than 2 degrees are necessary, something else should be wrong.
                • billf1973
                  • Feb 2011
                  • 127
                  May be more then 1/4in.
                  • Diegoboy
                    • Mar 2007
                    • 7244
                    Does she run a solid prop shaft?
                    That seems to be too much negative angle
                    • billf1973
                      • Feb 2011
                      • 127
                      No its a flex shaft .130
                      • Diegoboy
                        • Mar 2007
                        • 7244
                        Level that prop angle first.
                        • Heath M
                          • Mar 2008
                          • 806
                          Try setting ur strut the same depth as the sponsons with about 1 degree of negative angle. Also straighten the rudder to 90 degrees, it's got way to much negative angle.
                          Brisbane,QLD, Aussie
                          • billf1973
                            • Feb 2011
                            • 127
                            When I first set the the strut it was level with the bottom of the hull(touching the hull). After running it for the first time I knew the prop needed more down angle. Moved the prop down and tried it again, same results.
                            • billf1973
                              • Feb 2011
                              • 127
                              I will be changing rudder angle and prop shaft soon. Thanks guys!
