My P1 35" sub floor came completely unglued from the hull.
  • rjsmachz
    • Sep 2011
    • 1
    My boat is 11months old....no accidents and my sub floor came completely unglued. Any suggestions for fixing? glue types?
  • antslake
    RC nut
    • Nov 2010
    • 214
    Epoxy resin. I layed an additional layer of fiberglass in my hull. If you plan on doing speeds more than 25mph you should do the same. The gel coat will crack.
    • EricSchlaifer
      • May 2012
      • 38
      On some of the boats the wood also could use another coat of a poly resin since its quite thin. This will help keep the wood sealed.
      • lenny
        • Sep 2010
        • 4293
        I pulled my wood out for the cells,
        To get a lower cg in the hull.
        My cells are on the floor of the hull now and it help a lot for smooth running.
        ? ONLY IF THEY WORK
