I wanted to start a thread specifically on prop selection for the P1. Post your stats:
Prop and work done to it
cell count and what battery
Speed
Amps
watts
rpm's
and maybe a little write up on how you think the prop is, and how you got the measurements
I'll start:
x437/3 sharpened by fine design
4S 5400 20C venom
38mph
69amps
1236watts
31300rpms
Good prop with lots of bite. Has a tendency to torque roll the boat in the chop. I am using eagle tree 150amp data logger with gps and rpm sensor.
x437/3
3S 3200 Kokams
23mph
40amps
450watts
18,000rpm's
Great combination for wave jumping, and letting the kids learn on it.
x437/3
5s
44mph
88 amps
1510 watts (peak)
36000+rpm
too much prop for 5S
y536 sharpened and polished myself.
4s
36mph
67 amps
1100 watts
31500 rpms
Prop has less bite than the 3blade. Great handling for the boat, but the prop is slower, most likely because I messed up the cupping when I sharpened it. My first prop. I am doing more work to it now. I am turning more rpm's and going slower with it, which shows signs of slipping.
If you don't have all the numbers, just post what you can. I have a x438 to try. I also bought a x435, and x432 to try, but the shaft size was too small, made a mistake in ordering I guess. I need a smaller prop for running 5s and 6s on the stock setup, or maybe this is just too much for this boat.
I took my y536 and cut the tongues off, and I am going to try it next chance I get.
Speed
Amps
watts
rpm's
I'll start:
4S 5400 20C venom
38mph
69amps
1236watts
31300rpms
x437/3
3S 3200 Kokams
23mph
40amps
450watts
18,000rpm's
x437/3
5s
44mph
88 amps
1510 watts (peak)
36000+rpm
4s
36mph
67 amps
1100 watts
31500 rpms
