My buddy just got his P1, and from watching it run, it looks like it could benefit from some turn fins. Maybe 50 to 60mm ish??? Couldn't hurt right? That stepped hull seems to shimmy a bit in tight turns.
Turn fins a good idea on the P1?
Tags: None
Also tuck the rudder in, I mentioned it in a different P1 thread but my tucking the rudder (negative) in it will help with bouncing in the turns by allowing the transom to get in the water more and not run to high. It would be a good place to start while waiting for turn fins to come in. I know by doing that on my SV, it made a HUGE difference for the better.Comment
Cool. I'll let my buddy know to give it a try. It makes sense. Thanks. Do you know if a slightly kicked back rudder will flow any more water through the pickup? Being that if the bow is a little higher while running then the pickup is parallel with the surface of the water. Or does that make no sense?Also tuck the rudder in, I mentioned it in a different P1 thread but my tucking the rudder (negative) in it will help with bouncing in the turns by allowing the transom to get in the water more and not run to high. It would be a good place to start while waiting for turn fins to come in. I know by doing that on my SV, it made a HUGE difference for the better.
Hobie: As for the turn fins. They should be at a 90 deg angle to the bottom of the hull. That's how I mounted mine anyway.Comment
If it did it would be such a small amount it doesn't matter, JMO. But I don't think it would make a difference. Onething I always do is open the hole on the rudder more with a small rat file, that makes a big difference. I ran my SV tucked with ul power and my temps always 100-110F on motor and esc. That combo runs so cool I love ul-1 power. I'm on my 3rd boat, with ul power a ul, sv and now my h&m mono. Ran fast, cool and AMAZING in every boat.Cool. I'll let my buddy know to give it a try. It makes sense. Thanks. Do you know if a slightly kicked back rudder will flow any more water through the pickup? Being that if the bow is a little higher while running then the pickup is parallel with the surface of the water. Or does that make no sense?
Most monos have em.
