programming the king of shaves for 6s
  • robsextreme
    • Aug 2011
    • 2
    what is the easiest way to program these speedo's to run right on 2 - 3s lipos
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    You dont. They will blow. The stock motors will cook too if thats what your still using. For 6s running, you ll need to upgrade the motors and esc's and the drivetrain too.
    • robsextreme
      • Aug 2011
      • 2
      In the manual it says it will run on 2 3s lipos. I just cant get the program card till wednesday
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        It means one 3s lipo per side. They do not get wired in series. One motor runs off one pack, the other runs off the other pack.
        • fleckster48
          • Apr 2012
          • 40
          Hello...can you please tell me where I can find the esc programming card for the kos
          Thank You
          John
          • tlandauer
            • 5666
            John, I am not sure it will work, I am guessing that Venom's ESC is the same as Seaking ( Hobbywing). I have the first edition of this boat and the ESC looked identical to the Seakings I have been using in my other boats, it will be helpful if other more knowledgeable member can enlighten us!
            • fleckster48
              • Apr 2012
              • 40
              Ok, thank you for the update. There doesn't seem to be allot of data from Venom on this esc other than using transmitter to program it.
              • lenny
                • Sep 2010
                • 4294
                http://www.hobbypartz.com/hobbywing-...cards-box.html
                ? ONLY IF THEY WORK
                • lenny
                  • Sep 2010
                  • 4294
                  Yes, It is a seaking esc and works with the LED program box.
                  ? ONLY IF THEY WORK
                  • tlandauer
                    • 5666
                    Thanks, Lenny, for confirming it.
                    • lenny
                      • Sep 2010
                      • 4294
                      ? ONLY IF THEY WORK
                      • tlandauer
                        • 5666
                        BTW, John, this program box works for land vehicles as well as airplane, if you order it, it comes with three stickers for each type of applications, just for your info. It is so easy to use, i love this as compare to the radio programing way which my pea brain can't remember anything i did a second before!
                        • fleckster48
                          • Apr 2012
                          • 40
                          Hey, thanks for all the notes. I ended up picking up a HobbyWing card for $8 on ebay. It only has the boat sticker on it but it works ok for what I need it for.
                          • lenny
                            • Sep 2010
                            • 4294
                            Are you running the stock motor ?
                            ? ONLY IF THEY WORK
                            • fleckster48
                              • Apr 2012
                              • 40
                              Yes, stock motors and after running the programming card I found out that the ESC's were not set up the same. No protection was set and the port engine timing was set to 3.75 and the starbord was set to 26.25. So my question is, what do you guys normally run for timing? Thank You
