EKOS replacing the outrunners????
  • Vinnie909
    • May 2011
    • 30
    k so ill get my Mic out and see what size the inside of the clamp is and what size the shaft is
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      Originally posted by Skullcracken
      Thanks for the feedback but the new mounts are around the can. They don't have bolt mounts for the end of the motors like Venoms old green motors. The Feigao's fit, and perform better than the outrunners that are stock on the newer EKOS. The 540 size is definitely out. Limited to 380's or replace the mounts.
      I can help ya if you want to replace the mounts. I have some that are designed for use in that hull that epoxy in fairly easily. Water cooled too. Would have to change the couplers for the 5mm shafts on 540 motors...
      Just a thought.
      • Skullcracken
        • May 2010
        • 617
        Originally posted by LarrysDrifter
        Correct me if I'm wrong, but if you are able to install 380 motors in your mounts, Arc makes 380's in various kv's. They have a 2800kv that would scream and run cooler than any fegiao 2 pole. Very efficient motors. Use 120 amp speedos with x442's and you'll be sittin pretty.
        Thanks. I'm going to try that. So arc 2800kv 380's and x442's. I like it!
        • Vinnie909
          • May 2011
          • 30
          Just a thought.
          can u post me a link to what u have in mind, i wanna swap my stock motors out, and im willing to changes the stock mounts out too
          • tman
            • Jun 2011
            • 113
            how ca I tell if the ekos has the outrunner motors in it?
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              The cans spin.
              • Skullcracken
                • May 2010
                • 617
                Should I get the ARC 28mm-47mm 2800kv's? Can I run those 4s each? If so great.
                Also does ARC have a big nasty motor to replace the Leopard 4082 for my Genesis cat single drive?
                • ctstike
                  • Feb 2011
                  • 32
                  feigao 380 xl is a liitle bit loose n venom outrunner motor mounts u need to put a spacer in it,,,,, i got one of those 2 but never try it yet,,,,, i dont have money, need to drive 10,000 miles to buy some parts "_"
                  PUSH the PEDAL to the METAL
                  • ctstike
                    • Feb 2011
                    • 32
                    how many cell n ur 4s @larry?
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3278
                      I don't understand the question. The batteries are 4000mAh 40-50c 4s. I also use four 2s, 5000mAh, 50c packs. Two wired in series per side for 4s.
                      • ctstike
                        • Feb 2011
                        • 32
                        you got it 40-50 cell tnx larry
