Scorpion HK's in EKOS
  • nate
    • 1652
    Does anyone think these motor's would work on 5s, 442's and CC240's lv?
    HeliDirect has a huge selection of RC helicopters, helicopter toys and remote control helicopter. Get ultra fast shipping times direct to your door.
    LMT
    LehnerMotorenTechnik.com
  • forescott
    Hopelessly Addicted to RC
    • 2686
    Probably would work fine, but twin motors running 6s is gonna be a lot of battery weight for that hull. It already sits pretty low in the water with large 4s packs!
    • nate
      • 1652
      Actually I think I'd go with the Feigao 540xl 2,0xx motor, and pull the mount's and replace with these.. why has no one thought of these motor mount's?
      http://www.offshoreelectrics.com/pro...rod=grp-1157.2
      LMT
      • forescott
        • 2686
        I think 540's on 4s is a better choice too. I think these mounts are better though. You can get them "flat" and bend them any way you want!
        • nate
          • 1652
          I had one that I planed to use on my pt21 build and it was tall. Probably too tall for the ekos hull. I want to keep it low to the hull. After I fiberglass these plastic mount's in they should be solid. I used one in an XzessEvo2 hull worked great.
          How does your hull handle at 50mph?
          LMT
          • nate
            • 1652
            There was a video of an ekos hull with twin scorp's on youtube, I believe it went to the 70's..does anyone recall this?
            LMT
            • forescott
              • 2686
              50 mph is no sweat! Approaching 60 mph it gets pretty light. I ended up moving my esc's on top of the tunnel and the lipos forward into the sponsons to keep it planted when I ran it with the x-442s. It still was pretty sketchy @ 61mph which was the fastest she's gone.
              • richt
                • Dec 2010
                • 67
                which one of the 540xl motor 8xl 0r the 9xl
                • forescott
                  • 2686
                  Either will work ok. I'd actually think the xl's are a little overkill in the small 31-inch hull. "L" sized motors are more than enough if your upgrading to 540's. 8xl's will scream with 442's!
                  • richt
                    • Dec 2010
                    • 67
                    thanks for your help.
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3278
                      Rich,have you looked at the Venom King of Shaves threads?There are a few combos and set ups there that might answer a few questions.It will give you a good baseline idea on what you can do with yours.
