OK I have a set of venom prop shafts. there is a paper in there explaining rotation. But i need to make sure. because i think there is a problem
If your looing at the lines of the prop shaft and the end of it that hookes to the motors is pointed up and the end of it where the prop goes is pointed down.
if you look at the lines and the go from bottom to top in the swirl and they look like the are shapped like this / that is the left rotation cable and it has the counter clockwise prop (looking at the props from the back of the boat)on it that is on the right side of the boat if the boat is pointed nose up tail down. and if you look at the other prop cable and you see the lines going \ this is the right rotation cable and it gets the clockwise prop (looking at the props from the back of the boat) on it and it sits on the left side of the boat right?
