VENOM EKOS 4S 5000mah LIKE BUTTER
the 2 things i believe the reason are,
over prop...should be 32mm
and stingers are set alittle to neg...boat still runs slightly nose down
gunna go abit more pos on stingers..should get me to about 45max
also gotta get the 2lb of water out thats coming in..bummer
i am glad that vikos is out there so you all can see i am not the only (lucky)
person on here....o yea..vikos you also owe me a thank you....
for taking all of the abuse and name calling so we can have a clam discussion
about the ekos on 4s....
go to the other EKOS 4S 5000mah LIKE BUTTER thead and you will see what i meen(mean)Comment
WOT...YES INDEED,
motors run coolest and most efficent @wot i have found.
plus i added all kinds of extra cooling.
4s 5000mah i am getting 15-20 mins now with the venom charger compared to
the 8 mins on the other charger i was using
and thats beat you don't have a gps i was hoping you could give
me your top speed and i could compare it to mine.you using 32mm
and me using 36mm prop,i am betting you could go wot
for a couple of seconds to get it.also can you tell me your run
time on the 4s?just need someone to compare numbers against..thanxComment
ok I'll check run times...ran the boat a second time on 4s and ran fine..way to much chop the boat kept bouncing..I could clearly see the red props every time she passed by...which is why Ithink the shaft came on done. A coupler set screw got flung out of the hole,put everything back together locktite this time gona run her this morning soon as my packs balance...welll with 2 WOT runs and one half throttle pass my motors are no where as hot when I use to run WOT throttle...but again you have additional cooling on the boat so that might also be why..my skipping was not allowing for good cooling even with 0 degree trim she still hopped...even flipped it and kept going. My friend took the video on his HTC EVO trying to figure out how to send it so I can post it. I might go to radio shack and buy a GPS since there pretty cheap these days and take some speed runs.To scared to put my GPS application from my iPhone in there and lose my phone lol....Comment
vikos,
go on ebay to get your gps..
got mine for 20 bucks delivered brand new(garmin gecko 101)
gives max speed, time and alot of other stuff.....fits nice and neat to.Comment
Where are you mounting your gps? I have the little garmin forerunner that I usually mount with velcro in front of the battery tray. But recently found that I can pick up a little speed by shoving my gps in the back between the fake little exaust ports. Its a tight squeeze but I gained a couple mph because I changed the c.o.g. slightly. Food for thought!Attached FilesComment
Yeah, the gps is supposed to be water proof up to 3m. Unfortunately theres not much room in the ekos to adjust the center of gravity with the batteries (even if you remove the trays)Comment
i have mine same place forescott shows his but the rear is
a good idea...once i finish all my tests i will try in rear and
see what changes....
any issuses with signal back there?
the window up front gives alittle view of the sky...maybe its
not needed..(the window that is)Comment
I just don't like the way the window likes to fog with moisture in side makes me thing electronics are getting wet. But hull tape is amazing I must say. My stingers are at -1 or -2 no reading just trial and error but I doubt it'll make a difference in choppy conditions. Boat will still skip. Hey Scott I'm surprised ur not running on 4s with ur set up. Or are u. Are those 9xl u got running. This Saturday will be the 5th time she runs on 4s with no issues other than a coupler screw coming undone and shaft sliding out part way. How is a piece of silicone cooling tube sopost to help from not losing a shaft anyways.Comment
